Daz Studio Lip Animation
Hello,
I'm working with Daz3D 64bit, I've read in a couple of forums that a work around to getting lip sync to work is to also run 32bit. I lose some of the information in my character when I open it in the 32bit and I'm worried it will cause issues switching apps all the time. I'm also experiencing issues with my G8 female character and the lip sync- it's only moving her head up and down. Not her lips.
Does anyone know a way to create a good lip sync even if it involves external apps.
THANK YOU :)
  • Richard HaseltineRichard Haseltine Posts: 111,992
    If you have panes open in the 64 bit version  that don't appear in the 32 bit version open you will probably need to reopen them (from Window>Panes(Tabs) or by right-click in an empty area of the pane group next to the existing tabs). I'm not sure which information you would lose - do dForce settinsg get dropped? In any event, you can always use a clean base figure to do the lip-sync, then save as a Pose preset with just the needed settings and apply that (in the 64 bit vesion) to your full figure.
