A GAP IN THE TEETH!
Hello Richard (Haseltine)
Happens something strange in Genesis 3 Female. No morphs, no chracters, no JMC's. right the base Daz character. A gap in the teeth! Like you see in the pic, she has all teeth with gap and a little
rounded on the edges. Using or not Mouth Realism HD they do the same thing. I tried to replace everything from the Start Bundle G3F but nothing change.
Thanks!
859 x 864 - 77K
  • Dax AvalangeDax Avalange Posts: 342
    edited March 2019
    Hey Richard, found the reason about this bug! I try to explain more easy as possible.
    In the bottom pic, you see the path usually I use to save my FBM. You can see my default name Max as vendor name, Prouct as Product Name". Well, right that folder make confusion. I tell you way:
    Time ago I saved a character FBM, I don't remember wich one. I wrote Max-S as vendor name, but by wrong I pressed Accept and it start to save not the FBM only, but all the content you see in the Library using the default name Product. I didn't see that before and I saved new FBM later. So now, all the previous FBM depends from that folder Product (.../data/Daz 3D/Genesis 3/Females/Morphs/Product, instead Max-S), and all the JCM's are in that folder as well. Funny thing, G3F base character also need of teeth from that folder, if I rename you see the teeth gap. So, how to delete that folder and bring back the right default path?
    526 x 756 - 54K
    Post edited by Dax Avalange on
  • Richard HaseltineRichard Haseltine Posts: 111,715
    I'm not sure what is happening here.
  • Me too! Anyway in few words, any new FBM set the new Product folder. Simply things to do is fix the FBM without the Product folder, then save again the character with default folder and game is done. Simple wrong path! yes
