HDMesh..
Milo_471560Milo_471560 Posts: 511
the advert for it here http://www.daz3d.com/sales-promotions has at the bottom a showing for HDMesh in Daz Studio 64bit coming to the entire line of Genesis 2 Figures. Do you think we will get this with Carrara. Is this so you can do finer detail if you use GoZ or can export to 3d-coat do you think?
  • rk66rk66 Posts: 452
  • CarltonMartinCarltonMartin Posts: 147
    DAZ_jared said:
    Cbird said:
    Thank you for the answer Jared. So compatibility with outside software, but DAZ's own. Hmmm.
    The HD morphs don't work in the current version of Carrara 8.5
    Is this why C9 was planned for so quickly, perhaps?
  • Milo_471560Milo_471560 Posts: 511
    Maybe so.. of course I have been away from the forums is there any good scuttlebut on C9?
    rk66 said:
    It does.. just means the high end product is left out again :)
    Not much scuttlebutt for C9. I think everybody is still working through the C8.5 kinks and features. ;-)
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,803
    edited January 2014
    interesting
    RawArt Deep sea creature exported as obj with subdivision has HD morphs
    here he is in carrara as duf gouraud next to the HD obj
    wondering if I can use this somehow as a morph target?
    trying transfer tool with morphs enabled in studio will post result
    1921 x 1033 - 359K
    1920 x 1080 - 315K
  • bighbigh Posts: 8,147
    looks ok to me
    1040 x 780 - 152K
    edited January 2014
    ok but not HD
    see this thread http://www.daz3d.com/forums/discussion/36134/
    one done in Bryce
    1434 x 695 - 602K
    month open
    1040 x 780 - 423K
    you are missing my point Bigh
    when I have finished what I am doing will post results
    edited January 2014
    ok one is default deepsea creature .duf in carrara, the other my rerigged HDmesh version
    1920 x 1080 - 9M
    edited January 2014
    closer
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    I just checked the DS to iClone face stuff - looked ok
    didn't take it over to iClone yet .
    Did you check it out in iClone ?
    have the default not HD version, very smooth fish
    the rerigged HD version too much crashes 3dx5
    thanks
    have a good day
    I finally got my HD rerigged mesh into iclone
    1920 x 1080 - 3M
    interesting
    From what I understand, that's how it's done - you export from DS with subD level set to the res that you need, which creates all of the high res polygons for real, instead of as subD. Then you sculpt 'till your heart's content. But I think you need a special plugin for DS to bring the HD Morph back in. A Pixar technology. Something like that, anyways.
    will play with him more in carrara
    you know the wireframe render IS subdivided if you import a duf scene! just not morphed fully
    so it SHOULD be possible to implement somehow in carrara using the displacement possibly as others have said
    carrara creates 3D mesh from displacement just like this does from those mysterious morphs.
    if only one could map those morphs on a texture map!
    I did a quickish iClone video with a tiny bit of carrara
    Exactly. I agree about the SubD and how there should be some way to make it work in Carrara. But when I asked, they said that we need a plugin for it to work. Something with Pixar technologies - or something like that. Carrara does a great job of SubD, so I'm hoping that we get the plugin for us.
    edited February 2014
    OK it imports into Poser 2012 and a saved cr2 loads in carrara but has two meshes
    a genesis and a subD
    I cannot separate or hide one
    it loads mimic and aniblockks!
    weightmaps broken
    might try fenrics script
    1920 x 1080 - 523K
    fenrics Poser weightpaint fixed the rigging but still got that Siamese conjoined HD twin unmorphed Genesis mesh I cannot remove either if one could somehow combine them?
    1920 x 1080 - 163K
    1920 x 1080 - 41K
    1920 x 1080 - 636K
