Is there an Iray Dermatologist in the House?
aaráribel caađo
I decided to convert a character that was using SC Joy for Genesis 3's default settings (I think) to a dual-lobe, chromatic SSS model, based on another character skin that's been very successful across many lighting conditions. Initally, I started by messing with the settings, but I started to get werid results with green SSS artifacts, so I started again, using the same material settings as the original character (figure 2 in the attached render). I swapped out the textures and lowered the saturation and boosted the luminosity of the various color channels to get the pale skin I was after. Things went weird again. I triple checked to make sure I wasn't missing textures, emission was turned on, and everything else I could think of. Then it occured to me that maybe the scene got bugged, so I loaded the other figure and rendered: it comes out fine.
I can't figure out why I'm getting this completely bizarre effect. In previous versions, it looked like the HDRI was being used as a map inside the skin shader (which it isn't). Any suggestions on fixing or trouble shooting this?
Update. Additional testing showed that this estreme SSS with bizarre colors comes from the Chromatic SSS mode. I can't figure out why it's bugged for this character but not the other.
I went back to my usual settings for this character, tweaked it a bit and all was good. Then I turned the SSS from Mono to Chromatic and it immediately went wacky. I didn't render it out this time, but took the attached screenshot.
