Duplicate Formula found linking Value & Value
After creating several new custom morphs and saving them as morph assets, I get the following message in scenes using that character. WARNING: fileinput\dzassetdaz.cpp(5970): Duplicate formula found linking Value & Value in D:/Daz/My Library/Scenes/testscene.duf.
Is there any way to figure out exactly what morph is causing this or fix it without deleting all my morphs and creating them again?
  • Richard HaseltineRichard Haseltine Posts: 111,686
    Have you checked the log file? One thing that can cause it is running ERC Freeze twice for the same properties - can you recall if you did that (did an ERC Freeze, found the settings needed adjustment, ran ERC Freeze again)?
  • FalcoFalco Posts: 269
    Yea, thats the only entry from the log file so it doesn't narrow it down unfortunately.  Running ERC twice is probably what did it, I just don't remember which one of the morphs it was on.
    Would the duplicate formula show anywhere in the morph settings or the text in the dsf file so I can figure out which one it is?
    Yes, they would be in the .dsf file for the proeprty that the link was set to save with.
    Bleh, I ended up finding it after baking/freezing all the morphs again.
