Can You Change the Path of the Manifest Archive?
I'm trying to install my large Content Library onto my new SSD. My older SSD is a C drive, and I've given my new SSD the letter Q. I initially installed a lot of my content through DIM, and I directed both DIM and DS to my Q drive. However, as I installed my content, I noticed that my storage in my older C drive was increasing along with my storage in my Q drive. I think the reason DIM was doing this is it was still installing manifest files onto my C drive. But when I attempted to change the path of the Manifest archive from my C drive to my Q drive, it reverted right back to the C drive. Is there some way to change the path of the Manifest Archive?
  • NorthOf45NorthOf45 Posts: 5,896
    I believe you have to restart DIM after changing the path.
  • Epic82Epic82 Posts: 131
    Hello, NorthOf45,
    I've restarted DIM after I changed the path, but the path of the Manifest Archive still reverts back to my C drive.
    edited March 2019
    Check to see if the new path is being saved in the DIM configuration file in the following location:
    C:\Users\username\AppData\Roaming\DAZ 3D\InstallManager\UserAccounts
    Edit the .ini file with your Daz account name and look for "CurInstallPath" (should be near the top). Sorry, that should be OverrideManifestDir
    Post edited by NorthOf45 on
  • Richard HaseltineRichard Haseltine Posts: 111,374
    What path atre you trying to set? It may have non-standard characters thata re causing issues.
    Thank you both for your help. NorthOf45, I believe your suggestions have helped me solve my storage problems.
