Carrara object "explosion"
How can I create an "explosion" of my object in Carrara 8.5. I know I have to insert a particle emitter.
Thanks
Weet335
  • DUDUDUDU Posts: 1,945
    Hi,
    Carrara doesn't have a fracture tool, only a simple modifier with bad results, but usefull in some cases.
    My workflow is to use the plugin "Thrausi" in Cinema4D to break anything you want imported from Carrara and export the simulation as .obj sequence.
    After that, I use the "DCG/Obj Seq.importer" plugin in Carrara to import the .obj sequence.
    I often use the first multi-.obj exported, separate the different parts and run the physic simulation into Carrara.
    This is the basic of this process, you can of course, add some particles in your scene, use the displacement painting for your debries etc...
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,827
    the modifier does fracture the mesh but it's like an egshell because models are hollow
    what you can do is actually export it after the first frame and get an obj mesh you can reimport and add thickness to in the vertex room then run that through a bullet physics sim
    and composite the render with much fire and smoke to hide the transition in the animation
  • DiomedeDiomede Posts: 15,469
    Very clever!
  • StezzaStezza Posts: 9,298
    edited March 2019
    you can also apply the explode modifier to an object then use the free plugin 'Convert deformed object to mesh' and then add thickness to it..
    heres one I did to a cube
    just can't remember where on the Carrara forum the plugin is... frown
    640 x 480 - 103K
    Post edited by Stezza on
    it must do the same as export with morphs and skinning just one step
    the thickened reimport (or that mesh) for physics would need splitting BTW I am not sure if Carrara would do it though a softbody modifier would help make bits separate simulated.
  • rk66rk66 Posts: 452
    @Stezza
    DCG´s Anything Grooves
  • 3drendero3drendero Posts: 2,037
    Direct link to the free plugins: http://www.digitalcarversguild.com/carraraplugins.php
