Link Genesis8 shaping 'sliders'
I am new to daz studio and apologise if my lingo is incorrect.
I am attempting to 'link' waist circumference and chest circumference to a new 'slider' that will allow me to manipulate both simultaneously.
Can anyone please help me understand how I can achieve this?
Regards,
Adrian
  • Richard HaseltineRichard Haseltine Posts: 111,913
    1. Set both to the values you want when the master slider is at 100%, with everything else zeroed
    2. Right-click on the Parameters pane and check edit Mode, if it isn't.
    3. Right-click in the group you want to add your slider to and select Create New Property
    4. Edit the settings - name/label, and probably limits
    5. Set the slider's value to 1 (or 100% if it'ss et to display as percent)
    6. Right-click on the new slider and select ERC Freeze
    7. Check that the right things are listed in Sub Components and click Accept
    8. Test
    9. Optionally, File>Save As>Support Assets>Morph Asset and select the new slider - this will make it available to every figure you load based on that version of Genesis.
