Question about "Poser" content in Daz Studio
dannagiusy64dannagiusy64 Posts: 477
edited March 2019 in The Commons
Does this product work with daz studio?
https://www.daz3d.com/hallow-s-cauldron
Post edited by dannagiusy64 on
  • L'AdairL'Adair Posts: 9,479
    edited March 2019
    I don't have that specific product, but I do have a number of "Poser" products that work to some extent or another within Daz Studio.
    You might get an answer sooner if you change the title to: Question about "Poser" content in Daz Studio. As it is, most people who know nothing about Poser would think they can't answer your question.
    To edit the title, locate the little gear icon to the right of the star in the upper right corner of the post, on the same line as the title. Click on that icon and a popup will allow you to select "Edit". This will open up the your original post in the editor, where you can change the title, or add information to the body of the post.
    You can also use the drop-down at the top where you can select a different Category. I recommend you change the category to The Commons, where a much larger community base can have the chance to see and answer your question.
    Post edited by L'Adair on
  • ok. Thanks smiley
  • Richard HaseltineRichard Haseltine Posts: 112,003
    It says it uses custom materials, if it means a nodal sahder set-up from the materials Room (like the DS Shader Mixer) those won't load. The lights would also be expected not to load correctly. The model itself should load, but you'd have to redo the materials and lights.
  • Thanks, since it costs little I think I buy it. I need a cauldron for a project and I like that. I hope to be able to use it.
    Thanks, since it costs little I think I buy it. I need a cauldron for a project and I like that. I hope to be able to use it.It says it uses custom materials, if it means a nodal sahder set-up from the materials Room (like the DS Shader Mixer) those won't load. The lights would also be expected not to load correctly. The model itself should load, but you'd have to redo the materials and lights.
    There are various shader presets for 3Delight (Gloopy shaders for the AoA SSS shader, I think) and Iray (some of Jen Greenless' in the PC, as I recall) that may be useful for the evil brew.
