Reg. Daz Install Manager
PetraPetra Posts: 1,157
I have  My Library in my Documents on D drive, but the path to install is a different one by default in DIM.
Can I just add the new path and remove the default / recommended one?
I usually install everything manually but, I have trouble with 2 garments of the MrsChow 8 prob bundle and thought if I install that pro bundle with DIM, it might work.
Thank you :)
  • LeanaLeana Posts: 13,642
    Yes, you can add a new path and remove the default one in DIM settings.
    If you add your "usual" library DIM will probably warn you that there's non-DIM content installed in that directory when you add the path, but it should work when you add it anyway.
  • PetraPetra Posts: 1,157
    Thank you so much for your quick reply :)
    I shall do that now.
