Dark Corrosion Shaders
Hi, just recently purchased the Dark Corrosion shaders, and just about every surface in try to use them on just shows as gray. On one model I tried other shaders, both 3d- Delight and Iray and they were fine. Tried the DC shaders and grey was all I got. Anybody have a similar issue with these or other shaders. I have used many and first time I'm seeing this. any thoughts. Thanks
  • SorelSorel Posts: 1,438
    The shader will display one you render. The way it is set up for 3delight it dispays as grey in the viewport.
