Dforce clothes with poke through.
davesodaveso Posts: 8,378
edited March 2019 in The Commons
I used this harem set  https://www.daz3d.com/dforce-harem-pants-outfit-for-genesis-8-females
Elbows and under chest area, some on upper arms. I tried to enlarge the top .. sort of worked, at least elbows .. but now its too large overall
The image show after "fixed" .// obviously osmething not right. the item is described as low polygon ..maybe thats the problem?
1200 x 1200 - 695K
Post edited by daveso on
  • 3Diva3Diva Posts: 12,058
    edited March 2019
    I think dForce often turns off smoothing after a simulation - did you try turning Smoothing back on (under the Parameters Tab)? If it's already on, you might up the Smoothing Iterations and/or the Collision Iterations.
    Post edited by 3Diva on
  • davesodaveso Posts: 8,378
    yes, i did turn smoothing on ... will try the iterations. I did another in a different pose and it worked fine..without such an elbow bend...
