HDRI floating feet
Is there a way to fix this? So that the character does not look like they are floating in the air? What I have been doing is zoom up closer so the feet are not showing, but what if I whant a more zoomed out shot
  • FishtalesFishtales Posts: 6,231
    In the Environment Tab do you have Draw Ground set to On? Is the figure standing on the ground? Ctrl/D on Windows with it selected will drop it down.
  • nemesis10nemesis10 Posts: 4,008
    And the ground has two options: auto when you don’t want the HDRI ground to interfere with an environment ground and the feet will float, and manual where the feet will be flat on the ground. Carl or Cmd D will drop your figure to t
  • jedijuddjedijudd Posts: 606
    Thank you both, that worked
