Fingernails not rendering for a G8M using 3ddelight?
hi
I am rendering a character I made in 3d delight, I have applied skin texture jpgs that I created myself and they look as expected  in the rendered image,  but the character's fingernails render white with tiny dots which I take to mean that maybe the texture is missing?  I crated a custom arm texture jpg which includes the fingernails and I selected it under the Surfaces>G8M>fingernails,  is there another step ?  When something  renders white with tiny dots, does that inply that the texture map is missing ?
thanks
    A render of the issue and perhaps your render settings would be most helpful...did you load your skintexture into the diffuse color slot? Or is it empty? Have you tried applying some other character's fingernails? Does that work or are they rendering white with tiny dots?  smiley
