COMP DOWN USING OLDER COMP
Right my comp gone and untill get money fix amd using older laptop can render poser 11.
i dont want redownload studio 10 as to buggy and slow, i need a way transfer my daz 10 external to hard drive to use on old laptop as only using gen 1 and 2 for now.
dont want search downlaod again all me stuff.
i only load iray then export as obj to render in poser and vue as studio takes up all your memory and locks your processor at 100%
and lot studio users looking for older studios to use as they had enough of crashes lockups and other problems studio causing
  • imsaneukimsaneuk Posts: 51
    Using my studio 2 and 3 at moment
  • If you're referring to your content/assets, the simplest solution would be to pull the drive from the dead computer, place it in a USB adapter, full housing or drop in, then plug it into your laptop.
    Use there or transfer to the laptop.
  • Richard HaseltineRichard Haseltine Posts: 111,241
    I'm not fully following that, but if you are looking for an older 4.x and don't have back-ups of the installers then I believe you only option may be 4.5, which - as I recall - is supplied as part of the SDK.
    What i mean is i can copy my studio 2 and 3 to external drive run from thier on another computer.
    What i need is to copy from program from old hard drive then run from external on ohert computer, or put into studio again if downlaod it.
    i dont want to downlaod then go through everything i purchaes to reinstall again,
    You wouldn't need to reinstall content, just the application, plug-ins, and some (mostly older) shaders and scripts that plae fiels n the application folder.
    Ta info everyone
