Polygonal offerings: all Iray?
James_H
in The Commons
I get that some of these are props (cicada) and some are rigged (crab). So I assume the props are just what you see. But on at least one there is specific mention of Iray, on others there is not: so are these all Iray or just where Iray is mentioned?
If someone finds out, I'd be grateful for a heads up.
doesn't take much finding out...just look at the storepages. some of the items are .obj/.fbx, so they are not optimised for any render engine. the others mention on the page if they are optimized for Iray....
they are all including the crab 3D scanned objects so all one mesh AFAIK
The crab is rigged, which means it has the bones setup. so that would make it posable.
The birds dont mention that.
Pity the cicadas and the birds are taken from dead originals, you can see the pin hole on the textures of the cicadas and they look dried up.
thank you, i wouldn't have noticed by myself. "nice" to know.
Usually, when I see something described as a "prop", it means that it's not posable. I don't know if that's a general convention in the industry, but I've seen it used that way fairly consistently.
Hi,
All materials have been configured with iRay in mind. Regarding current offerings: only the Crab is rigged.There is always a trade-off between functionality and photorealism IMO. My focus is on scanning, so yeah ocasionally, artifacts, like the pinholes will show up...
Hope this is enough info. Enjoy and thanks for your support.
Polygonal
Does this mean iray material is incuded? Or do we have to create ower own shaders for iray?
Since they are scans, no.
Laurie
Iray Materials are included.
Branches are part of the model, but the block underneath the vulture can be removed.
Thanks, Polygonal. I thought that was the case, but the item descriptions are not consistent in mentioning Iray, so I thought I'd ask (I use Iray).
