On The Floor ?
waldek22waldek22 Posts: 0
Hi everybody :-)
I'm new here so please ,please be gental :)
I just started to use DAZ 3D 4.6 , I wached all the tutorial videos , but there is qestion I can't find awser for .
How do I make sure that my actors and props are on the floor after I do all the pose changes ???
Thanks for your time
  • StratDragonStratDragon Posts: 3,291
    ctrl+d on Windows (cmd+d on Mac) should drop the lowest portion of the figure to the floor but it doesn't always work. You may need to drop everything that is going to the floor with these command keys and see if they all "know" where the floor is then adjust your floor or you may just need to adjust the objects Y-translation until it looks like it's on the floor, this is called 'eyeballing it' and this has given me the most accurate results after many moons of using Studio.
  • waldek22waldek22 Posts: 0
    Cool......... thank you so much ,I knew it must be something easy :red:
  • Richard HaseltineRichard Haseltine Posts: 111,992
    You can also use the Align pane, but as with Drop to Floor it can be confused by certain objects and it does depend on the floor not having lots of projections since it works on the limits of the item.
