How do I convert a carrara item to a daz item?
https://www.daz3d.com/arboretum-volume-2
How hard and expensive would it be to convert something from Carrera to a daz-friendly item? I need the ironbark tree for a book cover.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,588
    well you can check show full detailed mesh in the plant room and export an obj but they are dreadfully high poly devil
  • WillowRavenWillowRaven Posts: 3,787
    Well ... does anyone know of another Ironbark tree model available?
  • Charlie JudgeCharlie Judge Posts: 13,629
    Does it specifically have to be an ironbark or would another species of Australian Eucalyptis work?
    Has to be specifically an Ironbark... The name of the book is Ironbark Hill
    Unfortunately there is no actual ironbark tree according to the web since that name refers to several species of eucalyptus trees in Australia
    https://en.wikipedia.org/wiki/Ironbark
    Might find one here
    https://www.cgtrader.com/3d-models/eucalyptus-tree
    https://www.turbosquid.com/3d-model/eucalyptus
  • GreymomGreymom Posts: 1,148
    XFROG has excellent models of several species of Eucalyptus, but I don't think any they have any called Ironbark.  You might check their products.  I guess that Eucalyptus paniculata is the Grey Ironbark and Eucalyptus tricarpa is the Red Ironbark (the one in the Arboretum Vol. 2)?
    E-On Software's Plant Factory does not seem to have either of those species in that selection either.
    Sorry, not sure where else to look.
    Ok, this is a long shot, but I remember reading somewhere that the most practical way to convert something from Carrara is to export it as a Lightwave object (.LWO) instead of .OBJ, and then import that .LWO file with the other software.  I was interested in how to go from Carrara to VUE, and have not tried this myself.
    obj export will work, it just will be a very high resolution object
    you even can add wind and rustle and load exports along the timeline as morph targets, I have done that
