Can you turn off reflections in Collective3d Create a Room
I have Collective3d Create a Room Xpack 3, and it has the most amazing reflective windows. However, these are slowing down my renders and I'm wondering if there is a way to turn off this property? Thanks in advance for any help.
Post edited by ValKyrie on
given that is Iray and photoreal (PBR) all you could try is lowering the Gloss Layer Weight so the reflection isn't as strong.
Thanks! Where do I find that? I used to be able to get right into the specular highlights and bump maps sections from within DS, but that was awhile ago and I can't find that stuff now. So much to learn!
I am presuimg you are using Iray but no matter the render engine all surfaces of an object are controlled in the Surfaces Pane.
