remove subdiv level
I have a simply ask: I would like remove the "high resolution" from my prop. How can I make?
I have a prop and converted it to subD. But I dont need high resolution, only the base. Can I delete the high resolution level?
  • SimonJMSimonJM Posts: 6,108
    As far as I know you can't remove the SubD, but you can set, via Properties, Mesh Resolution to Base, and just below that you'll be able to set the Render SubD Level (Minimum).
  • No, once it's converted there is no way to remove the conversion in daz studio.
    You'd need to reimport the prop and not convert it.
