Normals for Audrey? (SOLVED)
reserv888reserv888 Posts: 1,164
The Audrey character has two icons for Normals On and Off, but I can't see any difference in the renders.
Can some please explain what "normals" are and what i am doing wrong?
Post edited by reserv888 on
    Normal maps are another way of doiing bump mapping
    Why not trying pushing the button and see if you can see the difference.
  • reserv888reserv888 Posts: 1,164
    Thanks for your reply Chohole.
    I have made renders (the render one can do directly in the viewport) with Normals turned On and Off. No difference what I can see.
    edited March 2019
    @reserv888
    You may need a closeup to see differences. I'm also not conviced that the Iray viewport and an actual render give the same results. The few times I have used the Iray option for the viewport, the lighting looks different from an actual render. FWIW.
    Post edited by fastbike1 on
  • FSMCDesignsFSMCDesigns Posts: 12,855
    Go to the surfaces tab and select the figure and then go to surfaces and select the torso, or arm, or face. There will be a slot called Normal Map. If there is a blue texture there and a value asssigned to it, then your normals are active.
    Normal maps are like a general bump map and when used with a bump map, the bump gives you finer details. Lots of thimes you will need to increase the subdivision to see the effect of these maps.
    471 x 634 - 211K
    Thanks a lot chohole, fastbike1 and FCMCDesigns for your replies. When rendered close-up there is a small difference not noticeable in the viewport.
    Thanks also for educating me what Normals are used for.
