G3F to G8F Morph Loader Bent Front Teeth
Hi
When I transfer some G3F characters to G8F using Morph Loader Pro I get strange bending on the front teeth - the bottom of the teeth bend forward.
I make sure when I create the G3F .obj I zero the Mouth Realism HD dial, so this isn't the issue. Has anyone else experienced this and knows how to fix it?
1000 x 700 - 245K
I have seen distortion of the teeth going the other way, transferring a character morph from G8F to G3F. I worked around it be creating a selection set on G3F in the Geometry Editor for everything but the teeth, then in MLP using the Attentuate By option and choosing the EverythingButTeeth selection set. I was surprised how well it worked. It might work less well with morph extreme morphs, in which case I guess you could add a corrective morph to straighten the teeth. I overlooked the possibilty that Mouth Realism HD could be involved.
I find if you leave Mouth Realism HD on it spreads out the teeth. Which is fine if you want gaps. So I make sure when I save the the .obj I zero everything apart from the base shape (including any nipple or navel dials if they have values). I can always turn these back on on G8F after the morph transfer.
