iRay GPU rendering RTX2060 not working?
Hey,
I am guite new to Daz3D and having rendering problems. I cannot get GPU rendering to work. I have searched the net and found no solution. Daz3d Studio shows my GPU in rendering settings, but when I disable CPU rendering and try to render, the render window just pops up and Daz3D just doesnt do anything. In my logfile I get the following(and much more);
2019-03-08 16:17:57.588 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.0   IRAY   rend error: Cannot render: found no usable devices.
and at the end of render attempt:
2019-03-08 16:17:47.012 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(IRAY:RENDER):   1.0   IRAY   rend warn : GPU 1 (GeForce RTX 2060) with CUDA compute capability 7.5 cannot be used by iray photoreal.
2019-03-08 16:17:47.012 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(IRAY:RENDER):   1.0   IRAY   rend warn : There is no CUDA-capable GPU available to the iray photoreal renderer.
Why is it not working? Substance Painter uses Iray also, and GPU rendering works just fine. And in Blender GPU rendering with Cycles works (I know different engine).
  • Richard HaseltineRichard Haseltine Posts: 111,875
    Are you using daz Studio 4.10.0.123 (the release build) or 4.11.0.236 (the Public Build - the beta)? Only the latter supports 20x0 cards.
  • tonfro38tonfro38 Posts: 0
    Thank You. Yes, I am using 4.10.0.123. Just a quick guestion. Is the beta version stable? Just starting to learn so it is easier when you don't have to worry about what's a bug or what am I doing wrong.
    It seems to be yes, it's been out for a while.
