Help with the Severed Man
I have the Severed Man for Genesis and Genesis 8.  The problem is, I have some Gen 3 and Geb 2 zombies.  Any ideas on how to make either of these products work with my zombies?  Obviously, what's really needed is a Severed Man for Gen 3 but that's what I can't find.
  • TheKDTheKD Posts: 2,711
    Compositing multiple renders in post would probably be the easiest way to go I think.
  • Fastest, non post work, solution I could come up with is to create a custom transparency map, just black out the uneeded area, and parent the geograph to the body part to be removed.
    For decapitations, products already exist for g2 and g3.
    Anothet option would be to use something like the mannequin for g3f, which has geographs pretty close to the arm severing of the g1 arms.
    At least the lower arm, anyway.
    Haven't tested further.
    Its a bit off so some scaling after fitting to maybe necessary.
  • XyetztXyetzt Posts: 27,518
    This https://www.daz3d.com/mannequin-for-genesis-3-female is good I guess for severed body but not for parts like a severed hand.
