Anybody tried the Scarf Braid Hair in Poser?
TheWheelManTheWheelMan Posts: 1,014
When I try to load it , it asks for an .OBJ file that, as far as I can tell, is non-existent.
  • Faeryl WomynFaeryl Womyn Posts: 3,777
    I just checked the what's included and features and it says DUF and CR2 but does not say anything about an OBJ...I think someone made a mistake with the files. Will see what else I can find out.
    According to this readme, there is no obj, someone definitely made a mistake with the files.
    http://docs.daz3d.com/doku.php/public/read_me/index/17264/file_list
    edited October 2013
    PoserCFs for Dson Importer never come with OBJs. Open up the CR2 in a text editor, since it's only PoserCF, there shouldn't be anything in it except
    version
    number 9
    runPythonScript "NameOfProduct.py"
    which launches the associated python file, which itself launches the duf file via dson and converts it and uses the Runtime\DSON\auto_adapted folder.
    Post edited by Lissa_xyz on
  • TheWheelManTheWheelMan Posts: 1,014
    Okay, I'll check the file and see what's in it.
    Well, ok, it turns out there are OBJs involved. This DSON thing really creates a lot of unnecessary folders/files. When you load the CR2 for the hair, it should create an associated geometry file in Daz Studio Library\Runtime\DSON\auto_adapted\data (Daz Studio Library being whatever runtime you have mapped as the writable runtime folder in Poser under Scripts > DSON > Preferences).
    Thank you for the info, Vaskania. I found the file, and once I pointed the Importer to it, the hair loaded just fine. I don't understand why I had to manually do this, however. I also wonder if it will remember the location, or if I'll have to do this every time I load the hair.
    edited October 2013
    That I couldn't say. I don't have that hair to look at things. What version of the importer are you using?
