Alexandra 8 Skin
Hi, I bought Alexandra 8 https://www.daz3d.com/alexandra-8.
But my lady's skin is dark like soil even I change the translucency or put some lights on it.
How do i make the skin look like that in the promo page?
Do I need to buy skin shader? sry for noob question.
  • nemesis10nemesis10 Posts: 4,053
    Please add your render settings and whether you are rendering in iray or 3delight
  • ArgleSWArgleSW Posts: 161
    edited March 2019
    Whenever you do a render or use iray preview, make sure you are using an actual camera. If you are using the default perspective view, the look of the render will look broken.
    How to setup a camera:
    1. Click Create -> Create Camera
    2. Check 'Apply Active Viewport Transforms' and click accept.
    3. In the top-right of the viewport, change perspective view to the new camera you created.
    4. If you are using your own lights in the scene, also turn the headlamp off inside the camera's properties. Click headlamp on the camera properties and change it from Auto to off. If you scene looks pitch black, press CTRL+L to turn on preview lights which lights up the editor, but wont render in your scene.
    Post edited by ArgleSW on
  • 3Diva3Diva Posts: 12,058
    edited March 2019
    Try using her "Translucency Low" setting.
    If that's still not pale enough for your taste try turning the "Environment Intensity" up (if you're using HDRI lighting).
    Post edited by 3Diva on
    edited March 2019
    Here's Alexandra 8 with her Translucency Low setting and the default "RuinsB" HDRI and default Iray render settings - but with the Environment Intensity increased to 1.5:
    Due to the increased lighting, I think she's a bit shiny here, so I'd also recommend going to the Surfaces Tab, select her skin, and decreasing the "Duel Lobe Specular Weight" a tad. .40 should look nice, imo.
    615 x 800 - 547K
  • Wow, the image looks really nice. That's what I wanted.
    Thank you very much for all of your comments. I'll read through the comments over and over:)
  • nonesuch00nonesuch00 Posts: 18,897
    Render outside in Sun-Sky between 8AM - 7PM or a smaller window in it's winter, 1st 1/2 of spring or 2nd 1/2 of autumn.
    If indoors you can use this product after buying:
    https://www.daz3d.com/classy-cover-photo-light-set-vignette
    Or learn to use the lighting techniques that product or similar uses and set them up yourself for each render. If you search the internet for ShibaShake or SickleYield you will find they have some free tutorials done on lighting in DAZ Studio.
