"Smooth Polygons" in DS?
TaozTaoz Posts: 10,377
Poser has an option called "Smooth Polygons" under render settings that will smoothen out edges on e.g. shoulders, like those on the picture here. Is there a similar option or something else that can do the trick in DS?
549 x 723 - 227K
  • DogzDogz Posts: 912
    edited October 2013
    If using a object or figure that supports sub-D (e.g Genesis) then you can crank up the iterations under the parameters tab, you can also try playing with the smoothing angle slider under the surfaces tab for what its worth, although it wont effect the jagged appearance of the edges of your figure or object, (like in your above picture)
    But AFAIK there is nothing specifically in the render settings that deal with this.
    Post edited by Dogz on
  • Takeo.KenseiTakeo.Kensei Posts: 1,303
    edited October 2013
    Edit->figure/object->convert to SubD if it is not already subdivided then in parameter Tab, go to smoothing and up the Subdivision Level to 1 or 2 and set resolution level to High
    Post edited by Takeo.Kensei on
  • Richard HaseltineRichard Haseltine Posts: 111,992
    Note that the Subdivision level is for the viewport only, it doesn't affect the render in DS.
  • TaozTaoz Posts: 10,377
    Actually it's not a problem with G1 or G2, they'ree nice and smooth. It's only Gen 4 and earlier that has the problem.
    But SubD seems to fix the problem with V4 (haven't tried other figures yet), as you can see on this picture. DS often crashes though when I do the SubD, for some reason.
    704 x 828 - 105K
    edited October 2013
    OK, didn't try to change that anyway as it worked fine just by doing the SubD.
    Post edited by Taoz on
    Good point. On the subject, I have a question : which SubD level is used for rendering as we don't have any control parameter over that?
  • prixatprixat Posts: 1,630
    from my experiments it looks like a subD level of 3.
    Taozen said:
    ...SubD seems to fix the problem with V4 ... DS often crashes though when I do the SubD, for some reason.
    V4 has a lot of polys already, adding subD will push your system to its limits.
  • KatteyKattey Posts: 2,899
    What the purpose of SubD then, if it doesn't affect the render? I thought SubD was made specifically to make older chunkier models better to render.
    No he means that the Subdivision Level parameter only influence what we have in the viewport but the model is still subdivided at rendertime
    @Prixat : render a V4 without subD and with subD and have a close look at the shoulder. Having more polys doesn't mean it is better smoothed
    SubD at render time should be set by 3delght to be high enough to look like the limit state at the current resolution - DAZ_CJones did post a slightly fuller explanation recently, but that was the gist as I recall.
    I meant all the extra polys that subD adds is whats causing the crashes.
    Sorry. Thought you said it was not needed. Read too fast
  • StratDragonStratDragon Posts: 3,291
    What about OpenGL renders? I'm not trying to be a wise@$$, I'm seriously asking. I've never used sub-D in DS.
    OK - it was on a 32 bit XP system with 4 GB RAM, so that may be it.
    I think however there may be some memory leaks or something in DS, judging from the way it behaves in different situations.
  • BejaymacBejaymac Posts: 2,014
    edited October 2013
    Late DS1 or early DS2 they moved it to the Surfaces tab, that way you can set it differently on each material, it's called "Smoothing Angle" or "Smoothing" depending on which version of DS you happen to be using.
    The default is always on with the angle at 89.9.
    I should add that it doesn't matter how high you set it beyond the default 89.9 as nothing appears to change beyond that number.
    Post edited by Bejaymac on
    No, doesn't make any difference it seems...
  • BTLProdBTLProd Posts: 114
    Each level of Sub-D Quadruples the number of Polys. Also note that unless you have the /3gb option set at startup, the program can only use 2GB of RAM with any 32 bit Windows OS. You can very quickly run out of RAM running subdivision on a 70K poly figure.
    OpenGl renders would use the view port level and OpenSubDiv, I'm pretty sure - they certainly can't use the 3Delight algorithm.
  • BarubaryBarubary Posts: 1,233
    OK, I'm not sure I follow...
    Once an item has been converted to SubD, 3Delight automatically decides how many levels of subdivision it needs to apply?
    Yes. The left cube has a level of 0, the middle a level of 1 and the right a level of 2. As you can see they render identically.
    976 x 749 - 49K
  • Zig ZagZig Zag Posts: 96
    Richard,
    Are you sure about this? I just made a test render, on the left the sphere with subdivision, on the right without, 12 segments/12 sides per sphere.
    and subdivision affects rendering in my test case. Am I missing something?
    600 x 450 - 76K
    edited October 2013
    Ah ok now I understand, didn't read thoroughly, subdivision affects rendering but subdivision level does not.
    Post edited by Zig Zag on
    edited October 2013
    I thought the 3GB option was enabled by default (it is in Poser AFAIR). What's the reason it isn't?
    The switch needs to enabled at Windows start up (assuming that it's XP Pro, Home didn't have it) in order for Poser or DS to take advantage.
    So it's a Windows switch. Wonder how many DS and Poser users who know this. I've never heard about it before.
    Anyway, it seems to be a questionable thing to do, according to some of the comments to this article, e.g.:
    "The setting has a downside and should only be used when an important application requires or will benefit from the larger virtual address space. It restricts the system cache which will have a negative influence on system performance. There are other issues as well."
    http://dwf.blogs.com/beyond_the_paper/2009/04/enabling-3gb-switch-on-windows-vista/comments/page/1/#comments
    I used it on a lot of computers running 24h/24 at work and never had problem with but can't say it won't give problems on consumer desktop PCs
    I had that on Pro hardware and Software and appropriate tested drivers (and a few computers at home before x64 became standard) .
    You should test it to see if you have problems and revert back in that case. It's harmless, quick and easy and there is no risk. In the worst case you'll get some strange behavior with some drivers or program but I doubt it. Use it if you have 4Gb RAM on a 32 bit system and if you have some memory hungry programs (DS for example)
    Jesus Christ how did I never notice that O_O
    Anyway, thanks for the info, that might very well come in handy in the future :D
    OK. It's not a big problem though as I'm just running DS 32 temporarily on the XP machine for some testing. I do have the 64 bit version of DS installed on my primary rendering machine, and will also upgrade the XP machine to 64 bit soon anyway.
