How do you end an animation in the same position as the beginning?
wildbillnashwildbillnash Posts: 784
edited March 2019 in New Users
I was wondering if there was a way to copy the beginning pose of an animation and paste it at the end.  I want to animation to loop without the image jumping from the end position to the beginning position.
I tried to search the tutorials but several of the links are dead, one video doesn't have sound, or it just doesn't cover what I'm looking for.
Also, is there a way you can save separate animation that can be spliced together like the preset animation in AniMate Lite?
Post edited by wildbillnash on
  • Seven193Seven193 Posts: 1,156
    edited March 2019
    Does this work? Copy paste keyframes:
    https://www.daz3d.com/forums/discussion/172346/copying-and-pasting-keyframes-or-inserting-multiple-keyframes-at-once
    I think the first frame of animation has to be keyed to copy it?
    Post edited by Seven193 on
  • No, it's talking about dragging a box around a keyframe.  It won't do that.  If I'm correct, the keyframe is the little triangle in the timeline.  You can't drag a box around it.  There should be a "Copy Keyframe" option in the Edit menu.  That would help greatly.
    You need the kemate or graphmate plugins to be able to copy/paste and easily move keyframes. However you can go to frame 0 and select the figure, then rightclick on the parameterpane and choose memorize figure pose, then go to the end frame and choose restore figure pose.
    Yup, just save your animation as a pose preset (animated range).
  • wildbillnashwildbillnash Posts: 784
    edited March 2019
    What is the "parameterpane"?
  • Richard HaseltineRichard Haseltine Posts: 111,371
    The Parameters pane - Windoe>Panes(Tabs)>Parameters
  • Oh, thank you.  I'll try that.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,507
    Casual has a keyframe decimator that also creates loops
    https://sites.google.com/site/mcasualsdazscripts/mcjdecimate-for-ds-12-3
