Export from Daz (.dae) with UV maps
Hey guys,
Im exporting Victoria 8 as .dae.
But...
When I open in Blender, there is no UV map.
Are there any special setting I need to have UV mapping?
  • Richard HaseltineRichard Haseltine Posts: 111,867
    No UV mapping, or no textures?
  • JohnJohnFJohnJohnF Posts: 14
    Hello guys,
    Goal: export Victoria 8 (Marigold) with UV Map to blender
    I can view UV Maps of Victoria 8 on Daz (attach 1).
    I export as .dae (collada) with settings (attach 2).
    When opened in Blender, UV Map is not there.
    Do I need to configure anything before experting UVs?
    Thanks
    2872 x 1800 - 765K
    1346 x 1280 - 126K
    2852 x 1798 - 2M
  • andya_b341b7c5f5andya_b341b7c5f5 Posts: 694
    edited March 2019
    You won't see the UV map in Object mode in Blender.  Select the figure, switch to Edit mode and either select all the vertices, or click the 'Keep UV and edit mode mesh selection in sync' button at the top left of the UV editor window.
    Post edited by andya_b341b7c5f5 on
