Expression to Morph Dial
SirMixAlotSirMixAlot Posts: 10
edited March 2019 in Daz Studio Discussion
I have a custom G3 model with some morphs and face shapes.
Now i want to create some mophs dials for some new expressions. I followed this:
  1. Set all the morphs you want, and ensure that the character is otherwise zeroed.
  2. Right-click in the Parametrs pane and click Edit Mode, if it isn't already checked.
  3. Show the group you want to add your slider to, then right-click and select Add New Property (or possibly Create New property - going from memory).
  4. Set the New property to 1 (don't set its default value to 1 or it will always load set)
  5. Right-click on the new slider and select ERC Freeze.
  6. Double check that your new property iss et as the controller, and that the sub-components are just the morphs you want included. Click Accept
  7. Test your morph and, if satisfied and you want it always available, File>Save As>Support Assets>Morph Asset
    The Problem now is that i have to filter out the morphs that i used before from the morphs that i used only for the specific expression.
    Sometimes its to complex to separate this morphs. Is there an easier way to do this? Maybe set the facial expression from which i start as default to easy seperate the used morphs for the new expression?
Post edited by SirMixAlot on
  • Richard HaseltineRichard Haseltine Posts: 111,242
    What do you mean? That you haven't cleared the previous expression? Surely then you wouldn't be seeing the results you wanted anyway.
  • I mean that my custom G3 model already has some facial morphs added. This state is what i would call my "all time zero Face Expression" for this model.
    From this expression i want to create some other expressions as morph dials. But when i want to ERC Freeze my new expression i have to filter out the morphs that i used for my "all time zero face expression" and the morphs that i used for my new morph dial. expression.....sorry for my bad englisch its hard to describe.
    But why do you want to filter them out? If you want a sldier for the current expression then it needs the sanme settings as are in effect.
  • Lets say i always want my iris size to max. as my default zero facial expression.
    If i now use some other dials ( mouth/eyes open) for example and save them with ERC Freeze in a new dial morph, it will always shrink my iris size to normal size when i dial my new custom morph dial back to zero. If i dont want that i have to uncheck the iris size morph when i ERC Freeze.
    Therefore i´m searching for a way to easily seperate the "old" morphs from the "new" ones.
  • SirMixAlotSirMixAlot Posts: 10
    edited March 2019
    I found a small step to a solution. Maybe someone has an idea for the next step.
    When i go into the parameter settings i can change the value for the default state. When i now type in the current value to the default value, the morph won´t show up in the ERC Freeze list.
    If i would change in all morphs the default value to the current value for my "default zero morph", i would only get the "new" morphs in the ERC Freeze list.
    But changing them all by hand would take ages. Maybe there is a script or a way to change all used morph default value to the current value.
    EDIT:
    I found a solution and maybe someone else will find it usefull.
    Edit ->Figure->Memorize->Memorize Figure
    This will set all morph default values to the current state. If you now do some other morphs and ERC Freeze them in a new dial, only the new morphs will be in the ERC Freeze list.
