G2F Gens and toon shaders
Testing6790Testing6790 Posts: 1,091
edited October 2013 in The Commons
Hi all! I was just putting the finishing touches on one of my custom morph characters, adding hair, texture, gens, shaders, etc and I noticed something weird. When I apply the toon shader tan lines on the figure it works perfectly, but when I add the tanlines to the gens prop it is messed up.
The image could potentially be NSFW, tasteful clipping has been done.
It's not a huge deal, I can just not use the prop, but it's an official product so I'd at least like to understand why it layers strangely like that and how to fix it.
Link removed. Links to images with nudity must have filters
Post edited by fixmypcmike on
  • SotoSoto Posts: 1,451
    Probably a stupid question, but are you really, really sure both the figure and the genitals are using the same UV?
    I don’t use “G”2F, but looks like that.
  • Testing6790Testing6790 Posts: 1,091
    Oh god there's the issue. The toon shaders are set up for the V4 UV mapping and the gen prop doesn't have a v4 UV setting. Well dang. Does anyone know how to give it a V4 UV or fix the texturing when changing it to V6?
  • RenpatsuRenpatsu Posts: 828
    The V4 UV mapping comes with the "Victoria 4 for Genesis 2 Female" product, for both the G2F body and the DAZ made G2F genital geocraft - at least according to the file list in DIM. If you are using the DAZ geocraft and assuming that you got that "Victoria 4 for Genesis 2 Female" product, as your body texture seems to work, you may have to check if you got an update to install. If I recall correctly, the genital V4 UV map support there was added after release.
