My genesis 8(customized) can not close eyes
Hi, there
My genesis 8 character(customized in Zbrush) can't close eyes.
The face of the character was modified in the zbrush(goz). then, closed eyes(expressions morph) didn't work properly.
There are no hidden properties that affect it. only the morph from zbrush affects.
How do I fix 'Eyes Closed'?
2334 x 861 - 917K
  • Richard HaseltineRichard Haseltine Posts: 111,842
    You need a custom morph for the eyes to complete the closing - send the emsh to ZBrush with your morph applied at 100% and one of the eyes closed at 100% (and everything else zeroed), adjust the shape to have the eeys fully closed, send back to DS and in the options dialogue select Reverse Deformations (this subtracts your shape and the eyeclosing. Then you need to link the adjustment to both the Eye closed shape and to your shape - assuming you are in Edit mode in the parametrs pane, and have the three morphs (eyes closed left or right, your shape, and your correction) set to 100% right-click on your sahpe, select ERC Freeze, and in the dialogue select the Eye Closed shape for the Attenuate by option, and make sure that only the corrective morph is listed as a Sub component. That shoudl fix your issue.
  • You need a custom morph for the eyes to complete the closing - send the emsh to ZBrush with your morph applied at 100% and one of the eyes closed at 100% (and everything else zeroed), adjust the shape to have the eeys fully closed, send back to DS and in the options dialogue select Reverse Deformations (this subtracts your shape and the eyeclosing. Then you need to link the adjustment to both the Eye closed shape and to your shape - assuming you are in Edit mode in the parametrs pane, and have the three morphs (eyes closed left or right, your shape, and your correction) set to 100% right-click on your sahpe, select ERC Freeze, and in the dialogue select the Eye Closed shape for the Attenuate by option, and make sure that only the corrective morph is listed as a Sub component. That shoudl fix your issue.
    Thank you so much, finally I solved this problem.
