Problem reading saved scene after reinstallation of DAZStudio
MartialMartial Posts: 431
Bonjour
I have upgrading to Windows 8,1 and after a computer crash i have to reinstal all my c parttion and all my softs ,DAZStudio included
So i have reinstalled DAZStudio_4.6.1.17_Win64
My older folder where all my Daz Studio and content ,scenes etc was and were still installed
My partittion D: is still there and my DAZStudio is still where it was at
Sata part disk2 (D:\) DAZStudio 64 bits and all my content is in My library folder
I always installed my DAZStudio stuff in this location without problem since version 1
I Reinstall DAZDAZStudio_4.6.1.17_Win64 in this D:\ DAZStudio 64 bits folder
DAZStudio is loading ok and i have configured the preferences like before wth content directory manager locating my Poser runtimes
I can create an new scene but i cannot open again an scene saved before this installation
It is very annoying because i have saved many basic scene i used again and again
I got error messages like thes when i try to open a before saved scene
An error occured while reading the file see the log file for more detail
or
Some assets neesed to load the file were missing The content may not work as expected
The following files could not be found
Are there some settings i must change ?
Some suggestions ?
Thanks
  • fixmypcmikefixmypcmike Posts: 19,741
    Can you go to Help > Troubleshooting > View Log File and pot some of the lines near the bottom about missing files?
  • MartialMartial Posts: 431
    Here the last log i have
    i have verified : dzpropertyeditor.dll and d3dGenX.dll are in the plugin folder
    +++++++++++++++ DAZ Studio 4.6.1.17 starting +++++++++++++++++
    Platform bits: 64
    Qt Version: 4.8.4
    Running on Windows 8, Build 9200, No Service Pack Installed
    CPU Information:
    CPU String: GenuineIntel
    CPU Brand String: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
    Cache Line Size = 64
    L2 Associativity = 6
    Cache Size = 256
    Stepping ID = 9
    Model = 10
    Family = 6
    Extended model = 3
    CLFLUSH cache line size = 64
    APIC Physical ID = 4
    Supported CPU Features:
    SSE3 New Instructions
    MONITOR/MWAIT
    CPL Qualified Debug Store
    Thermal Monitor 2
    x87 FPU On Chip
    Virtual-8086 Mode Enhancement
    Debugging Extensions
    Page Size Extensions
    Time Stamp Counter
    RDMSR and WRMSR Support
    Physical Address Extensions
    Machine Check Exception
    CMPXCHG8B Instruction
    APIC On Chip
    SYSENTER and SYSEXIT
    Memory Type Range Registers
    PTE Global Bit
    Machine Check Architecture
    Conditional Move/Compare Instruction
    Page Attribute Table
    Page Size Extension
    CFLUSH Extension
    Debug Store
    Thermal Monitor and Clock Ctrl
    MMX Technology
    FXSAVE/FXRSTOR
    SSE Extensions
    SSE2 Extensions
    Self Snoop
    Hyper-threading Technology
    Thermal Monitor
    Pend. Brk. EN.
    Physical Memory:
    Total: 31.9 GB (34318168064)
    Avail: 27.8 GB (29862293504)
    Virtual Memory:
    Total: 127.9 TB (140737488224256)
    Avail: 127.9 TB (140737254891520)
    Current Memory Usage: 12%
    Current DateTime:
    Loc: Sat Oct 26 17:45:40 2013
    UTC: Sat Oct 26 21:45:40 2013
    Temp Data:
    Location = C:/Users/MF/AppData/Roaming/DAZ 3D/Studio4/temp
    Disk Total: 222.9 GB (239413579776)
    Disk Avail: 133.7 GB (143624003584)
    Locale: en_CA
    No translator found.
    Reading style definition D:/DAZStudio4 64 bits/resources/style/Main Street.style
    Creating managers
    Reading help index
    Reading help file D:/DAZStudio4 64 bits/docs/DAZ Studio/DAZStudioHelp.dsx
    Reading help file D:/DAZStudio4 64 bits/docs/Plugins/3DBridge/3DBridge.dsx
    Reading help file D:/DAZStudio4 64 bits/docs/Plugins/EXPExporter/ExPExporter.dsx
    Reading help file D:/DAZStudio4 64 bits/docs/Plugins/FBXExporter/FBXExporter.dsx
    Reading help file D:/DAZStudio4 64 bits/docs/Plugins/FigureSetup/FigureSetup.dsx
    Reading help file D:/DAZStudio4 64 bits/docs/Plugins/GoZ/GoZ.dsx
    Reading help file D:/DAZStudio4 64 bits/docs/Plugins/JointEditor/JointEditor.dsx
    Reading help file D:/DAZStudio4 64 bits/docs/Plugins/LayeredImageEditor/LayeredImageEditor.dsx
    Reading help file D:/DAZStudio4 64 bits/docs/Plugins/MorphLoader/MorphLoader.dsx
    Reading help file D:/DAZStudio4 64 bits/docs/Plugins/MorphLoaderPro/MorphLoaderPro.dsx
    Reading help file D:/DAZStudio4 64 bits/docs/Plugins/PolygonGroupEditor/PolygonGroupEditor.dsx
    Reading help file D:/DAZStudio4 64 bits/docs/Plugins/TextureAtlas/TextureAtlas.dsx
    Reading help file D:/DAZStudio4 64 bits/docs/Plugins/WeightMapBrush/WeightMapBrush.dsx
    Reading help file D:/DAZStudio4 64 bits/docs/inlinehelp.dsx
    Scanning import folders
    Scanning content folders
    Using GLEW 1.9.0
    Supported OpenGL extensions:
    GL_AMD_multi_draw_indirect
    GL_AMD_seamless_cubemap_per_texture
    GL_ARB_arrays_of_arrays
    GL_ARB_base_instance
    GL_ARB_bindless_texture : NOT INITIALIZED
    GL_ARB_blend_func_extended
    GL_ARB_buffer_storage : NOT INITIALIZED
    GL_ARB_clear_buffer_object
    GL_ARB_clear_texture : NOT INITIALIZED
    GL_ARB_color_buffer_float
    GL_ARB_compatibility
    GL_ARB_compressed_texture_pixel_storage
    GL_ARB_conservative_depth
    GL_ARB_compute_shader
    GL_ARB_compute_variable_group_size : NOT INITIALIZED
    GL_ARB_copy_buffer
    GL_ARB_copy_image
    GL_ARB_debug_output
    GL_ARB_depth_buffer_float
    GL_ARB_depth_clamp
    GL_ARB_depth_texture
    GL_ARB_draw_buffers
    GL_ARB_draw_buffers_blend
    GL_ARB_draw_indirect
    GL_ARB_draw_elements_base_vertex
    GL_ARB_draw_instanced
    GL_ARB_enhanced_layouts : NOT INITIALIZED
    GL_ARB_ES2_compatibility
    GL_ARB_ES3_compatibility
    GL_ARB_explicit_attrib_location
    GL_ARB_explicit_uniform_location
    GL_ARB_fragment_coord_conventions
    GL_ARB_fragment_layer_viewport
    GL_ARB_fragment_program
    GL_ARB_fragment_program_shadow
    GL_ARB_fragment_shader
    GL_ARB_framebuffer_no_attachments
    GL_ARB_framebuffer_object
    GL_ARB_framebuffer_sRGB
    GL_ARB_geometry_shader4
    GL_ARB_get_program_binary
    GL_ARB_gpu_shader5
    GL_ARB_gpu_shader_fp64
    GL_ARB_half_float_pixel
    GL_ARB_half_float_vertex
    GL_ARB_imaging
    GL_ARB_indirect_parameters : NOT INITIALIZED
    GL_ARB_instanced_arrays
    GL_ARB_internalformat_query
    GL_ARB_internalformat_query2
    GL_ARB_invalidate_subdata
    GL_ARB_map_buffer_alignment
    GL_ARB_map_buffer_range
    GL_ARB_multi_bind : NOT INITIALIZED
    GL_ARB_multi_draw_indirect
    GL_ARB_multisample
    GL_ARB_multitexture
    GL_ARB_occlusion_query
    GL_ARB_occlusion_query2
    GL_ARB_pixel_buffer_object
    GL_ARB_point_parameters
    GL_ARB_point_sprite
    GL_ARB_program_interface_query
    GL_ARB_provoking_vertex
    GL_ARB_robust_buffer_access_behavior
    GL_ARB_robustness
    GL_ARB_sample_shading
    GL_ARB_sampler_objects
    GL_ARB_seamless_cube_map
    GL_ARB_seamless_cubemap_per_texture : NOT INITIALIZED
    GL_ARB_separate_shader_objects
    GL_ARB_shader_atomic_counters
    GL_ARB_shader_bit_encoding
    GL_ARB_shader_draw_parameters : NOT INITIALIZED
    GL_ARB_shader_group_vote : NOT INITIALIZED
    GL_ARB_shader_image_load_store
    GL_ARB_shader_image_size
    GL_ARB_shader_objects
    GL_ARB_shader_precision
    GL_ARB_query_buffer_object : NOT INITIALIZED
    GL_ARB_shader_storage_buffer_object
    GL_ARB_shader_subroutine
    GL_ARB_shader_texture_lod
    GL_ARB_shading_language_100
    GL_ARB_shading_language_420pack
    GL_ARB_shading_language_include
    GL_ARB_shading_language_packing
    GL_ARB_shadow
    GL_ARB_stencil_texturing
    GL_ARB_sync
    GL_ARB_tessellation_shader
    GL_ARB_texture_border_clamp
    GL_ARB_texture_buffer_object
    GL_ARB_texture_buffer_object_rgb32
    GL_ARB_texture_buffer_range
    GL_ARB_texture_compression
    GL_ARB_texture_compression_bptc
    GL_ARB_texture_compression_rgtc
    GL_ARB_texture_cube_map
    GL_ARB_texture_cube_map_array
    GL_ARB_texture_env_add
    GL_ARB_texture_env_combine
    GL_ARB_texture_env_crossbar
    GL_ARB_texture_env_dot3
    GL_ARB_texture_float
    GL_ARB_texture_gather
    GL_ARB_texture_mirror_clamp_to_edge : NOT INITIALIZED
    GL_ARB_texture_mirrored_repeat
    GL_ARB_texture_multisample
    GL_ARB_texture_non_power_of_two
    GL_ARB_texture_query_levels
    GL_ARB_texture_query_lod
    GL_ARB_texture_rectangle
    GL_ARB_texture_rg
    GL_ARB_texture_rgb10_a2ui
    GL_ARB_texture_stencil8 : NOT INITIALIZED
    GL_ARB_texture_storage
    GL_ARB_texture_storage_multisample
    GL_ARB_texture_swizzle
    GL_ARB_texture_view
    GL_ARB_timer_query
    GL_ARB_transform_feedback2
    GL_ARB_transform_feedback3
    GL_ARB_transform_feedback_instanced
    GL_ARB_transpose_matrix
    GL_ARB_uniform_buffer_object
    GL_ARB_vertex_array_bgra
    GL_ARB_vertex_array_object
    GL_ARB_vertex_attrib_64bit
    GL_ARB_vertex_attrib_binding
    GL_ARB_vertex_buffer_object
    GL_ARB_vertex_program
    GL_ARB_vertex_shader
    GL_ARB_vertex_type_10f_11f_11f_rev : NOT INITIALIZED
    GL_ARB_vertex_type_2_10_10_10_rev
    GL_ARB_viewport_array
    GL_ARB_window_pos
    GL_ATI_draw_buffers
    GL_ATI_texture_float
    GL_ATI_texture_mirror_once
    GL_S3_s3tc
    GL_EXT_texture_env_add
    GL_EXT_abgr
    GL_EXT_bgra
    GL_EXT_bindable_uniform
    GL_EXT_blend_color
    GL_EXT_blend_equation_separate
    GL_EXT_blend_func_separate
    GL_EXT_blend_minmax
    GL_EXT_blend_subtract
    GL_EXT_compiled_vertex_array
    GL_EXT_Cg_shader
    GL_EXT_depth_bounds_test
    GL_EXT_direct_state_access
    GL_EXT_draw_buffers2
    GL_EXT_draw_instanced
    GL_EXT_draw_range_elements
    GL_EXT_fog_coord
    GL_EXT_framebuffer_blit
    GL_EXT_framebuffer_multisample
    GL_EXTX_framebuffer_mixed_formats : NOT INITIALIZED
    GL_EXT_framebuffer_multisample_blit_scaled
    GL_EXT_framebuffer_object
    GL_EXT_framebuffer_sRGB
    GL_EXT_geometry_shader4
    GL_EXT_gpu_program_parameters
    GL_EXT_gpu_shader4
    GL_EXT_multi_draw_arrays
    GL_EXT_packed_depth_stencil
    GL_EXT_packed_float
    GL_EXT_packed_pixels
    GL_EXT_pixel_buffer_object
    GL_EXT_point_parameters
    GL_EXT_provoking_vertex
    GL_EXT_rescale_normal
    GL_EXT_secondary_color
    GL_EXT_separate_shader_objects
    GL_EXT_separate_specular_color
    GL_EXT_shader_image_load_store
    GL_EXT_shadow_funcs
    GL_EXT_stencil_two_side
    GL_EXT_stencil_wrap
    GL_EXT_texture3D
    GL_EXT_texture_array
    GL_EXT_texture_buffer_object
    GL_EXT_texture_compression_dxt1
    GL_EXT_texture_compression_latc
    GL_EXT_texture_compression_rgtc
    GL_EXT_texture_compression_s3tc
    GL_EXT_texture_cube_map
    GL_EXT_texture_edge_clamp
    GL_EXT_texture_env_combine
    GL_EXT_texture_env_dot3
    GL_EXT_texture_filter_anisotropic
    GL_EXT_texture_integer
    GL_EXT_texture_lod : NOT INITIALIZED
    GL_EXT_texture_lod_bias
    GL_EXT_texture_mirror_clamp
    GL_EXT_texture_object
    GL_EXT_texture_shared_exponent
    GL_EXT_texture_sRGB
    GL_EXT_texture_sRGB_decode
    GL_EXT_texture_storage : NOT INITIALIZED
    GL_EXT_texture_swizzle
    GL_EXT_timer_query
    GL_EXT_transform_feedback2 : NOT INITIALIZED
    GL_EXT_vertex_array
    GL_EXT_vertex_array_bgra
    GL_EXT_vertex_attrib_64bit
    GL_EXT_import_sync_object : NOT INITIALIZED
    GL_IBM_rasterpos_clip
    GL_IBM_texture_mirrored_repeat
    GL_KHR_debug
    GL_KTX_buffer_region
    GL_NV_bindless_multi_draw_indirect : NOT INITIALIZED
    GL_NV_bindless_texture
    GL_NV_blend_equation_advanced : NOT INITIALIZED
    GL_NV_blend_square
    GL_NV_compute_program5 : NOT INITIALIZED
    GL_NV_conditional_render
    GL_NV_copy_depth_to_color
    GL_NV_copy_image
    GL_NV_depth_buffer_float
    GL_NV_depth_clamp
    GL_NV_draw_texture : NOT INITIALIZED
    GL_NV_ES1_1_compatibility : NOT INITIALIZED
    GL_NV_explicit_multisample
    GL_NV_fence
    GL_NV_float_buffer
    GL_NV_fog_distance
    GL_NV_fragment_program
    GL_NV_fragment_program_option
    GL_NV_fragment_program2
    GL_NV_framebuffer_multisample_coverage
    GL_NV_geometry_shader4
    GL_NV_gpu_program4
    GL_NV_gpu_program4_1 : NOT INITIALIZED
    GL_NV_gpu_program5
    GL_NV_gpu_program5_mem_extended : NOT INITIALIZED
    GL_NV_gpu_program_fp64
    GL_NV_gpu_shader5
    GL_NV_half_float : NOT INITIALIZED
    GL_NV_light_max_exponent
    GL_NV_multisample_coverage
    GL_NV_multisample_filter_hint
    GL_NV_occlusion_query
    GL_NV_packed_depth_stencil
    GL_NV_parameter_buffer_object
    GL_NV_parameter_buffer_object2
    GL_NV_path_rendering
    GL_NV_pixel_data_range
    GL_NV_point_sprite
    GL_NV_primitive_restart
    GL_NV_register_combiners
    GL_NV_register_combiners2
    GL_NV_shader_atomic_counters : NOT INITIALIZED
    GL_NV_shader_atomic_float
    GL_NV_shader_buffer_load
    GL_NV_shader_storage_buffer_object : NOT INITIALIZED
    GL_ARB_sparse_texture : NOT INITIALIZED
    GL_NV_texgen_reflection
    GL_NV_texture_barrier
    GL_NV_texture_compression_vtc
    GL_NV_texture_env_combine4
    GL_NV_texture_expand_normal
    GL_NV_texture_multisample
    GL_NV_texture_rectangle
    GL_NV_texture_shader
    GL_NV_texture_shader2
    GL_NV_texture_shader3
    GL_NV_transform_feedback
    GL_NV_transform_feedback2
    GL_NV_vertex_array_range
    GL_NV_vertex_array_range2
    GL_NV_vertex_attrib_integer_64bit
    GL_NV_vertex_buffer_unified_memory
    GL_NV_vertex_program
    GL_NV_vertex_program1_1
    GL_NV_vertex_program2
    GL_NV_vertex_program2_option
    GL_NV_vertex_program3
    GL_NVX_conditional_render : NOT INITIALIZED
    GL_NVX_gpu_memory_info
    GL_NVX_nvenc_interop : NOT INITIALIZED
    GL_OES_compressed_ETC1_RGB8_texture : NOT INITIALIZED
    GL_SGIS_generate_mipmap
    GL_SGIS_texture_lod
    GL_SGIX_depth_texture
    GL_SGIX_shadow
    GL_SUN_slice_accum
    GL_WIN_swap_hint
    WGL_EXT_swap_control : NOT INITIALIZED
    WGL_ARB_buffer_region
    WGL_ARB_create_context
    WGL_ARB_create_context_profile
    WGL_ARB_create_context_robustness
    WGL_ARB_extensions_string
    WGL_ARB_make_current_read
    WGL_ARB_multisample
    WGL_ARB_pbuffer
    WGL_ARB_pixel_format
    WGL_ARB_pixel_format_float
    WGL_ARB_render_texture
    WGL_ATI_pixel_format_float
    WGL_EXT_create_context_es_profile
    WGL_EXT_create_context_es2_profile
    WGL_EXT_extensions_string
    WGL_EXT_framebuffer_sRGB
    WGL_EXT_pixel_format_packed_float
    WGL_EXT_swap_control_tear
    WGL_NVX_DX_interop
    WGL_NV_DX_interop
    WGL_NV_DX_interop2
    WGL_NV_delay_before_swap
    WGL_NV_float_buffer
    WGL_NV_multisample_coverage
    WGL_NV_render_depth_texture
    WGL_NV_render_texture_rectangle
    : NOT INITIALIZED
    OpenGL features for current hardware:
    OpenGL provider: NVIDIA Corporation
    OpenGL renderer: GeForce GTX 660/PCIe/SSE2
    OpenGL version: 4.4.0
    Maximum number of lights: 8
    Number of auxiliary buffers: 4
    Number of texture units: 4
    Depth buffer bit resolution: 24
    Maximum OpenGL texture size: 16384 x 16384
    Current OpenGL Texture Quality Setting: Good Performance
    RGBA color bitplane resolutions: 8 8 8 0
    GLSL version: 4.40 NVIDIA via Cg compiler
    Shadow mapping supported
    VBO supported
    *** Scene Cleared ***
    Loading plug-ins:
    aniMate2.dll
    d3dGenX.dll
    D:\DAZStudio4 64 bits\plugins\d3dGenX.dll failed to load. Cannot load library D:\DAZStudio4 64 bits\plugins\d3dGenX.dll: The specified procedure could not be found.
    dazscriptide.dll
    dz3dbridge.dll
    dz3dconnexion.dll
    dz3dmouse.dll
    dzalignace.dll
    dzassetiofilters.dll
    dzautofit.dll
    dzautoriggercontrol.dll
    dzautoshaderbakeractions.dll
    dzbrycebridge.dll
    dzbvh.dll
    dzcolladax.dll
    dzcomponents.dll
    dzcontentdbeditor.dll
    dzcontentlibrarypane.dll
    dzcr2exporter.dll
    dzcustomizedlg.dll
    dzdecimator.dll
    dzdelightrenderer.dll
    dzdformeditor.dll
    dzeasyloader.dll
    dzexpexporter.dll
    dzfbxexporter.dll
    dzfbximporter.dll
    dzfiguresetup.dll
    dzgoz.dll
    dzhexagonbridge.dll
    dzimageio.dll
    dzjointeditor.dll
    dzlayerededitor.dll
    dzlayerfilter.dll
    dzmanualshaderbaker.dll
    dzmaptransfer.dll
    dzmorphfollower.dll
    dzmorphloader.dll
    dzmorphloaderpro.dll
    dzobjexporter.dll
    dzoptitexclothcontrol.dll
    dzpolygongroupeditortool.dll
    dzprimitives.dll
    D:\DAZStudio4 64 bits\plugins\dzpropertyeditor.dll failed to load. Cannot load library D:\DAZStudio4 64 bits\plugins\dzpropertyeditor.dll: The specified procedure could not be found.
    dzpropertyhierarchyeditor.dll
    dzpuppeteer.dll
    dzpz3importer.dll
    dzrenderedit.dll
    dzrenderlibrary.dll
    dzrslshadercompiler.dll
    dzsavefilters.dll
    dzscriptedrenderer.dll
    dzscriptedsteps.dll
    dzshaderbaker.dll
    dzshaderbuilder.dll
    dzshadereditor.dll
    dzshadermixerbase.dll
    dzshadermixergui.dll
    dzsmartcontentpane.dll
    dzspotrendertool.dll
    dztextureatlas.dll
    dztransferutility.dll
    dzu3dexporter.dll
    dzweightmapbrush.dll
    dzwinvideo.dll
    graphMate.dll
    lamhPlugin.64.dll
    sdk_sceneinfopane.dll
    dzdrawstyles.dll
    dzmimicrealtime.dll
    recentfiles.dll
    dzpowerpose.dll
    Reality_2.0.dll
    DEBUG: initDB!
    DEBUG: Db is Open
    Could not activate graphMate evaluation. Plug-in disabled.
    Could not activate Mimic Live! evaluation. Plug-in disabled.
    Error writing author data!
    Total class factories: 1290
    WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
    3D mouse support library could not be loaded.
    Creating interface
    Successfully created OpenGL viewport for Viewport1.
    Successfully created OpenGL viewport for Viewport2.
    Successfully created OpenGL viewport for Viewport3.
    Successfully created OpenGL viewport for Viewport4.
    Executing startup script...
    DEBUG: Error: Reality cannot find the Add-ons files on disk. Please re-install Reality
    Started in: D:/DAZStudio4 64 bits
    DAZ Studio Started
    Creating Pixel Buffer
    Pixel buffer - Width: 1024 Height: 1024
    Compiling OpenGL Shader...
    Fragment Shader:
    Fragment Shader compiled successfully.
    Linking Shader:
    Shader Program successfully linked.
    Can you try to load your scene and then go to the bottom of the log and just post the bottom?
    Thanks for reply Here is this:
    Opening file base genesis female Bf morphs bonsoir cloth assise chaise3c.daz...
    Error setting pointers while reading file D:/DAZStudio4 64 bits/My Library/scenes/base genesis female Bf morphs bonsoir cloth assise chaise3c.daz : C Exception: Memory Access Violation - Attempted to read memory at address 0x00000000
    File read time: 0 min 6.2 sec.
    Building Scene...
    Ran tdlmake on image D:/DAZStudio4 64 bits/My Library/Runtime/textures/DAZ/Characters/MilWom/V5/V5ValerieLimbsM.jpg
    Ran tdlmake on image D:/DAZStudio4 64 bits/My Library/Runtime/textures/DAZ/Characters/MilWom/V5/V5ValerieLimbsT.jpg
    Ran tdlmake on image D:/DAZStudio4 64 bits/My Library/Runtime/textures/DAZ/Characters/MilWom/V5/V5ValerieLimbsS.jpg
    Ran tdlmake on image D:/DAZStudio4 64 bits/My Library/Runtime/textures/DAZ/Characters/MilWom/V5/V5ValerieLimbsB.jpg
    Ran tdlmake on image D:/DAZStudio4 64 bits/My Library/Runtime/textures/DAZ/Characters/MilWom/V5/V5ValerieLashes.jpg
    Ran tdlmake on image D:/DAZStudio4 64 bits/My Library/Runtime/textures/DAZ/Characters/MilWom/V5/V5ValerieEyesO.jpg
    Ran tdlmake on image D:/DAZStudio4 64 bits/My Library/Runtime/textures/DAZ/Characters/MilWom/V5/V5ValerieEyes01Shadow.jpg
    Ran tdlmake on image D:/DAZStudio4 64 bits/My Library/Runtime/textures/DAZ/Characters/MilWom/V5/V5ValerieEyesB.jpg
    Ran tdlmake on image D:/DAZStudio4 64 bits/My Library/Runtime/textures/DAZ/Characters/MilWom/V5/V5ValerieEyesS.jpg
    Ran tdlmake on image D:/DAZStudio4 64 bits/My Library/Runtime/textures/DAZ/Characters/MilWom/V5/V5ValerieMouth.jpg
    Ran tdlmake on image D:/DAZStudio4 64 bits/My Library/Runtime/textures/DAZ/Characters/MilWom/V5/V5ValerieMouthB.jpg
    Ran tdlmake on image D:/DAZStudio4 64 bits/My Library/Runtime/textures/DAZ/Characters/MilWom/V5/V5ValerieMouthS.jpg
    Ran tdlmake on image D:/DAZStudio4 64 bits/My Library/Runtime/textures/DAZ/Characters/MilWom/V5/V5ValerieMouthO.jpg
    Ran tdlmake on image D:/DAZStudio4 64 bits/My Library/Runtime/textures/DAZ/Characters/MilWom/V5/V5ValerieLimbsSSS.jpg
    Here EXTRACTS from another try of loading a saved scene
    In this scene the meshes are loading but all is white on these objects
    WARNING: fileinput\dzassetdaz.cpp(4367): Could not find modifier definition.
    WARNING: fileinput\dzassetdaz.cpp(1301): Failed to prepare modifier!
    WARNING: fileinput\dzassetdaz.cpp(1310): Failed to create modifier!
    Could not resolve : "/My Library/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Head Morphs/PHMEyelidsTopInHeight.dsf"
    Could not resolve : "/My Library/data/DAZ 3D/Genesis/Base/Morphs/DieTrying182/V4_Eye height left_BODY.dsf"
    Could not resolve : "/My Library/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution Muscularity/PBMErectorSpinaeLateral.dsf"
    Could not resolve : "/My Library/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Victoria 5/MCMV5HdAfraid.dsf"
    Could not resolve : "/My Library/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Head Morphs/PHMTeethIrregular.dsf"
    Could not resolve : "/My Library/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Creature Creator/FBMZombie.dsf"
    Could not resolve : "/My Library/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Ethnicity/MCMAfrcnFemaleCHdUpEyesClsdR.dsf"
    Could not resolve : "/My Library/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Ethnicity/MCMNtvAmMaleBHdEyesClsdL.dsf"
    Could not resolve : "/My Library/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Ethnicity/MCMNtvAmFemaleAHdEyesClsdR.dsf"
    Could not resolve : "/My Library/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Creature Creator/PHMEarElfCurve.dsf"
    Could not resolve : "/My Library/data/DAZ 3D/Genesis/Base/Morphs/D3D Gen X/Victoria 4/V4_PHMEyeCloseTopR_head.dsf"
    Could not resolve : "/My Library/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Michael 3/FBMMichael3.dsf"
    Ran tdlmake on image E:/Poser 7/Runtime/Textures/Godin/Danysa_Textures/DanysaTorsH.jpg
    Ran tdlmake on image E:/Poser 7/Runtime/Textures/Godin/Danysa_Textures/DanysaTorsHB.jpg
    Ran tdlmake on image E:/Poser 7/Runtime/Textures/Godin/Danysa_Textures/DanysaFHB.jpg
    Ran tdlmake on image E:/Poser 7/Runtime/Textures/Godin/Danysa_Textures/DanysaHMU03.jpg
    Can you post a screenshot of your Content Directory Manager with both DS and Poser formats expanded, the the complete path to one of those missing files?
    Thanks for yours attention to my problem
    Here some print screen
    1107 x 1083 - 207K
    others
    1614 x 819 - 232K
    Having both "D:\DAZStudio 64 bits\My Library" and "D:\DAZStudio 64 bits\My Library\scene" listed may be causing problems -- nested content folders can make it hard for DS to determine where the Data folder is located.
    Can you pick one of the missing files and see what the full path to it is on your hard drive?
    Allo
    Two weeks ago
    Everything was working good ,even with two scenes folders at different localisations (because i begin outside My library and continue inside My Library--i dont remember why i have shifted)
    After my windows 8,1 crash and reinstalled windows on my c:\ drive , i have all my DAZSTudio stuff on my D:\ partition and I have just reinstalled DAZStudio again inside it
    And my problem was beginning
    I have tried today to change some settings without success
    I just have copied all the scenes in My Library but same problem is there
    Is there some .ini i can change manually ?
    I have a backup of my c:\ before windows 8 .1 .My be i can manually copy some files for DAZ Studio found in users ,program data or others, trying to reconstitue my before crash setting
    I know i have a very bad english but i am a french speaking person
    I thanks you for your effort to help me
  • JaderailJaderail Posts: 0
    I'm inclined to agree with Mike. As the Scene folder is listed after the main content folders DAZ Studio might be set to find the Data folder in it and not in the proper folder. Which I see is listed. Nesting breaks DAZ Studio paths in the Content loads.
    I'm thinking you ADDED those folders with DAZ Studio up and running on the Old set up. It worked then. The new Clean install of DAZ Studio started with the Paths Nested and this time it Saw the error and refuses to work.
    I think i find something
    I have a backup of all my DAZStudio 64 bits, dated of august 2013 ,on externe drive
    i make a comparaison with the actual one on D:\ (the one where i reinstalled DAStudio after my crash) and I find in the actual one a folder i didn't have on last august ,a folder in MY Library and called Databases wich contain these files:
    contentDb.blb
    contentDb.dat
    contentDb.ind
    contentDb.vdb
    master.vdb
    I try to change the name or cut and paste in a temp folder this Databases folder but i cannot
    Some suggestion please !!
    thanks
    contentDb.blb
    contentDb.dat
    contentDb.ind
    contentDb.vdb
    master.vdb
    thanks
    That's the CMS database -- it was probably in the default location on your old computer. But that wouldn't cause problems reading a saved scene.
    You need to move any Data and Runtime folder that's under My Library\Scene up one level and merge them with the ones under My Library, and remove that path from your Content Directory Manager.
    I did it but same problem
    I have two folder named data now one in D:\DAZStudio4 64 bits\MY Library and another in D:\DAZStudio4 64 bits
    Must have merge these two in one and where is suppose to be ?
    Same with Runtime
    I have one in D:\DAZStudio4 64 bits
    Another in
    I need to be sure because after merging it will be difficult to come back
    and after this what configuration i must put in my content manager ?
    Merci beaucoup
    Yes, merge them so the only Data and Runtime folders are directly under "My Library", and have only "My Library" set in both DS Content Directory Manager (both DS and Poser formats) and in DIM (although you can still have the Poser content folders as well, just no subfolders of My Library).
    Hello
    I did it and stiil error message
    Ouf !!
    Can you show us the Content Directory Manager as it is now, some of the error messages, and the full path to the files DS can't find? Was this scene originally saved in My Library/Scenes or in the Scenes folder outside of My Library?
  • StratDragonStratDragon Posts: 3,291
    edited October 2013
    So looking for my bug report I just ran into this:
    https://helpdaz.zendesk.com/entries/22469349-How-to-fix-a-DAZ-Studio-Scene-File-duf-with-legacy-figures
    Let someone know if this works, I can't do anything until late tonight when I'm home and get a moment of free time.
    Post edited by StratDragon on
    I just ran into this gem
    That's a different issue -- this is a .daz scene file.
    Note that a majority of saved scene in the past has error ,generally the textures are the problem The caracter is loaded without material
    Often often scenes with genesis and genesis 2 female and something from Poser are not correctly loaded
    I have imported some Poser file with success (.pzz)
    1020 x 1125 - 180K
    Again
    1059 x 687 - 192K
    1059 x 687 - 192K
    edited October 2013
    DAMN YOU POST EDIT!!!
    ok, I thought they might be related.
    sorry for the mixup.
    You need to have My Library listed under Poser Formats as well -- that should fix the missing textures. As for the missing Data files, can you pick one and find the full path to it?
    Like this
    But Still error message
    And note also that some scene seems loaded whithout error message but there nothing in the scene in DAZStudio
    492 x 387 - 52K
    The error message
    594 x 414 - 47K
    Martial said:
    The error message
    That shows a "My Library" folder underneath another "My Library" folder -- do you have a second My Library under My Library?
    No i have verified the first time isee this kind of message and see only one MY Library
    I see i also have this folder
    D:\DAZ\Content Management Service
    with many folders : databases (that why may be i didn't have it in my ancient installation), license, project etc
    This folder was there for a long time and now it have no refrence to it since new installation and all my C:\ drive is new after the crash
    The funny thing about this is that every thing was working perfecrtly two week ago with all my setting even they was not regular one
    I try to never install something in my SSD on c:\ except users preferences I want to keep my c partition as clean as possible and as small as possible because i frequenly backup it with Acronis True image
