Remove Script from Script menu?
Is there a way to remove a script once it's added to the Scripts drop-down menu of DAZ Studio?
I have looked everywhere for instructions but can't find any. There must be a way.
If you can add a script there must be a way to remove it as well.
Please help!
  • NorthOf45NorthOf45 Posts: 5,895
    Menu -> Window -> Workspace -> Customize (or just F3)
    Right half of the popup, select the Menus tab. Expand "+Main Menu". Expand "+&Scripts". Right-click on the offending command and select "Remove Item".
    It depends on how you installed it.
    If you used Daz Install Manager (DIM), just find the script there, select it and then press the green 'Start Queue' button.
    If you installed it manually in the 'My Daz 3D Library' or 'Daz 3D/Studio/My Library' you should be able to find the 'Scripts' folder and search there for the name of the script folder, and delete it.
    Unless someone else has a better way?
  • vonHobovonHobo Posts: 1,715
    Thank you NorthOf45! That worked!
    Never thought it would buried under all those steps.
    Thank you Dragonfly.
