ISO Retro Rocket for Iray
Charlie Judge
in The Commons
I'm looking for a retro style rocket that I can use in Iray with other Iray environments and HDRIs.. The rocket in 3Djoji's Toon Rocket and Moonscape would be just about ideal; BUT the texture do not convert well to Iray.
Any suggestions would be most welcome
Thanks
Why not use that Rocket with some Iray shaders? The default shaders that come with DS include metals (which you can colour yourself if you don't like the defaults) and glass.
If that rocket doesn't have enough material zones, it looks like there's enough geometry to make your own with the geometry editor.
I may wind up doing just that; but it may be somewhat time consuming. There are a ton of material zones. I tried using the RSSY 3DL to Iray converter but I wasn't happy with the results from that. But some of the 'Real Paint" shaders will work nicely when applied manually.
