Altern8 Lee 8
At first I thought this was AliveSheCried's Alt Lee 8 from Rendo, but this is a nice ALTERNATIVE to it! :D
https://www.daz3d.com/altern8-lee-8
  • 3Diva3Diva Posts: 12,058
    edited March 2019
    hahah It's called Altern8 because it's based on my skin shader product Altern8 Skin Shader System for Genesis 8 (though Altern8 Lee 8 is a stand-alone product and the Altern8 Skin Shader System product isn't required to use it). :)
    I wanted to note, since it's been asked on the other thread, that it DOES include shaders that can be used on other Genesis 8 Male, Genesis 8 Female, Genesis 3 Male, and Genesis 3 Female characters.
    Here are a couple of variations of Victoria 7 using the Altern8 Lee 8 Shaders.
    This one is- Maps Load Setting, Skin Shader 03, and Shine Strength Shader 08:
    This one is- Maps Load Setting, Skin Shader 04, Shine Strength Shader 09, and SSS Tint Shader 10:
    There are a total of 7 base skin setting shaders, 15 shine strength shaders, and 12 SSS tint shaders - that can be used on other Genesis 8 and Genesis 3 characters.
    Post edited by 3Diva on
  • Avid RendererAvid Renderer Posts: 1,213
    edited October 2019
    Tried using it on Lee 2, a great improvement. No postworks. Thanks for this awesome skin shader, Divamakeup.
    BTW, how do I reduce the redness of the ears?
    Post edited by Avid Renderer on
    edited October 2019
    That looks great! :D
    As for the ear redness, you can reduce that by either lowering the Transmitted Measurement Distance (located near the bottom of the Surfaces Tab) or lowering the Translucency Weight.
    Edit- BTW, I just checked and Lee 6 has ear redness/pinkness baked into his skin texture map. So while lowering the TMD or Translucency will help lessen the redness it might not be as effective as one would like due to the baked-in ear redness.
  • Tried using it on Lee 2, a great improvement. No postworks. Thanks for this awesome skin shader, Divamakeup.
    Don't delete the attachment after you place a link inline - it's still referring back to the attached file, so no one who comes on after the deletion will see the image.
    edited October 2019
    Thanks for the prompt response, Divamakeup. I reduced the TMD up to 0.042 as well as the light intensity. No postworks. I thought the redness disappeared substantially. I will try it on other characters also.
    4000 x 3077 - 8M
