Measure Metrics I don't get it
I bought the package downloaded and installed it, but the very first point in the tutorial doesn't work: Navigate to "Window">"Panes(Tabs)", select "Measure Metrics".
There is really no "Measure Metrics" there. Gonna shoot myself soon, nothing works so far.
  • Richard HaseltineRichard Haseltine Posts: 111,875
    Did you install the plug-in - there is also the Figure Metrics script and content. The plug-in must be installed with Install Manager. If you did, have you entered the serial number in help>About Installed plug-ins? You can get the serial number from the serial numbers page in your account, or from a right-click on the plug-in's entry in Install Manager.
  • It's installed but the Serial Number Field in Install Manager is greyed out. I just have an order number and nothing else. My problem is that I was searching for ages for this combination of programs and now nothing works.
  • I entered the serial number now and it works. BUUUUUT I want to modify the measurements I take, are you telling me I can only take measurments and not modify them? 49$ for using a ruler?
  • Yeah, I found the modify option now. Please erase my former comment. It's everything a little bit complicated for me.
  • dracorndracorn Posts: 2,384
    Take notes so that you don't go through this again. The height follower can be picky and not show a change. Get out of the measure view and onto the shaping tab. Change the height and return, and you should see the update. Also, when you delete the followers, some are buried in the scene tab. Click on the measurement plane in the viewport to select it.
