Problem with Toon Skeleton Robe
DisparateDreamerDisparateDreamer Posts: 2,520
edited October 2013 in The Commons
The lower skirt of the toon skeleton robe won't bend. The thigh bones, even when i dial them to bend,don't bend. Conformed or not. I'm using DS4.5. Maybe there's something that doesn't work? :( The shins and feet don't move the skirt either. The arms work fine but not the leg bones of the lower robe.
Edit: I even reinstalled to see if something got broken but no, it's like there's ghost bones, for the skirt of the robe to bend or twist or side to side, and none of them work at all. The robe is totally useless! I'm super bummed :( If I can only use the toon skeleton in standing only its a real let down!
Edit 2: Found the morphs in the figure, not in the hip or leg bones. They barely do anything tho, the bend of the skirt is less than 20 degrees I think.
My solution is to convert the toon skeleton to triax, convert the robe to triax, and then transfer rigging from skeleton to the robe. It rigs it like pants, which is of course not the most ideal, but at least I can make the skeleton sit in a robe now, and with smoothing it's actually pretty good.
Still a bit annoyed at how limited use the robe is though. :(
Post edited by DisparateDreamer on
