Surface tab/presets question regarding deleted materials and the persistence of their corresponding
I've deleted some material files that I created, but the icons for them continue to persist. They have an exclamation now. How do you get rid of the icons?
    From the Content Library or Smart Content pane Options menu (the rectangle with horizontal lines in the upper corner) > Content DB Maintenance > Remove Orphaned Items
  • edited December 1969
    Unfortunately I did not delete several materials via the content library as you explained, but deleted the material file from the folder it was in. Now i can't seem to remove the icons for those few via the method you explained. I know how to do it now, per you instructions, but i got about three icons that persist that I would like to get rid of.
  • JaderailJaderail Posts: 0
    edited October 2013
    You could also just Close DAZ and File Delete the Icons from the Folder or folders. Then the remove Orphans should work the next time you run DS.
    Post edited by Jaderail on
