What does this directory do?
HeraHera Posts: 1,972
Hello!
I've got a lot of files in a directory called DAZ other\Runtime\support - it's mostly product images. What's it for really?
  • RodrakRodrak Posts: 81
    Herakleia said:
    Hello!
    It's metadata used by CMS/smart content in daz studio.
  • fixmypcmikefixmypcmike Posts: 19,739
    Those are the metadata files for the products (the source for re-importing them or for exporting/re-importing user data).
  • Richard HaseltineRichard Haseltine Posts: 111,984
    It is used only if you need to reimport metadata, to rebuild the CMS database after a problem or if you want tos tart over for example (or if you manually install and then import metadata - but using the Install Manager the items are added directly to the database).
  • HeraHera Posts: 1,972
    edited November 2013
    Does this mean I can zip these files together or move them somewhere else, since they are beginning to take up a lot of room on the harddrive?
    Post edited by Hera on
    Yes, they are needed only when (or if) you reimport Metadata via the Content DB Maintenance dialogue.
    Thanks, that's what I wanted to know :)
