Mark IX Hawk for Poser is up.
The Mark IX Hawk from the Space 1999 episode 'War Games" is up for download.
Get it here; https://www.deviantart.com/greywolf-starkiller/art/Mark-IX-Hawk-OBJ-Version-787196440
1280 x 800 - 610K
  • An excellent mesh, thanks!
    Problem is, the mesh is all I can import into D|S. There's something odd about the .obj files, they aren't picking up the .mtl files at all. And all the texture pointers in the .mtl are absolute paths, linking to your WIP folder on your computer.
  • SixDsSixDs Posts: 2,384
    Excellent work! Thank you!
    (Some assembly required smiley)
  • I expected that. It's why I leave D/S conversions to those experienced with D/S. IIn Poser, I aimed the texture path in the Material room at the "Textures" folder in the Runtime.
    D/S should use the Poser settings. I wonder if deleting the mtl files might fix the problem. If you look at other OBJ files in the Geometries folder, few if any, have mtl files. I think
    the are more for OBJs colored by materials and not as important with textures. Still, I use D/S more than Poser, but still can't manage converting my models to it. When I first tested
    the mesh, before UVmapping her, I imported the full ship into Poser 7 and she came in with all materials set correctly, but importing into D/S resulted in no materials set at all. D/S must
    read it differently from Poser, and I haven't figured it out yet. :(
    edited February 2019
    That's because the settings in the .mtl files are — for Poser props and figures — in the .cr2 or .pp2 Library file, so the .mtl isn't really necessary.
    I decided to forget about the .mtl files and just manually apply the colours and textures listed once I've got the .obj imported cleanly. Here's my first rough try, all I did was apply a plain white plastic Iray shader, then add the texture map to all surfaces (except Window, where I applied a plain glass shader).
    Looks pretty good, I think. I'll add the other sections later, as I have time. Maybe I'll try a base metal shader instead of plastic, see how that comes out.
    1700 x 1190 - 71K
    Post edited by SpottedKitty on
  • lukon100lukon100 Posts: 860
    Sweet model.
    Just found an actual hiccup in the materials. The Booster Engines .obj doesn't have a .mtl file, and the .mtl for the Central Section has all materials light grey with no named texture file.
    Ah well, it all works — got all the bits converted to .duf, applied all the textures, and did a quick test render. I think I like it.
    1700 x 1190 - 77K
  • Great! I'm working on a DS version as well, for others to DL. Please check the commons as I requested some help with which files I
    need in the ZIP. Excellent job! ^_-
    Eric
    aka Starkiller
  • Heh — I just realised the missile launch tubes are angled outwards. An easy solution to the embarassing problem of shooting at the bad-guy-of-the-week and blowing up your own Command Module...
  • RedfernRedfern Posts: 1,649
    edited March 2019
    I've always had a soft spot for the "Altares", the "photon drive" ship from the one shot (hoped for "backdoor pilot") special titled "The Day After Tomorrow: Into Infinity".  It was one of those "afternoon specials" (or whatever NBC called its version) intended to introduce kids to the concepts of general relativity.  It was filmed between the first and second seasons of "Space: 1999" involving the production team from the series.  Nick Tate starred as the pilot of the craft, who along with his teenage daughter and a husband, wife and son team made up the crew.  I'm sure StarKiller knows about it, but for those who never caught it, think of it as Gerry Anderson's answer to "Lost in Space"...without a brew vat shaped robot or a simpering sabatuer.  Brian Blessed played the husband and father of the other family, into a surprising understated fashion.  No booming "Gordon's ALIVE?!" type performances here.
    I saw that special before I did the bulk of "1999" (it didn't air where I lived at the time) and was amazed by the miniature work which would not be rivaled until a certain lil space war flick debuted roughly 2 years later.
    StarKiller, if you ever get the urge to model that baby, keep me in the loop!
    Sincerely,
    Bill
    Post edited by Redfern on
  • Hmmm. I watched Space 1999 regularly, but somehow I missed this. Going to Google to check it out. In case I don't find much, please point me in the
    right direction when I'm back online. :)
    Heh, heh...  Prepare for "info dump"!
    https://en.wikipedia.org/wiki/The_Day_After_Tomorrow_(TV_special)
    https://www.google.com/search?q=day+after+tomorrow+into+infinity&tbm=isch&source=hp&safe=active&sa=X&ved=2ahUKEwjpouTqwuHgAhUSVa0KHY_4AKQQiR56BAgDEBM&biw=1102&bih=580
    http://catacombs.space1999.net/plus/dt/day0.html
    https://www.google.com/search?q=lightship+altares&tbm=isch&source=hp&safe=active&sa=X&ved=2ahUKEwj7x-_cw-HgAhVEPawKHfE6CvAQsAR6BAgFEAE&biw=1102&bih=580
    After I composed my original inquiry, I wondered if you might respond, "Why the synopsis?  I know about that one."  So I'm now kinda' surprised.  Anyway, these links should be a good starting point.
    Before comparative photos were available, a lot of Gerry Anderson fans thought the Altares was simply a redress of the Meta-Probe or Ultra-Probe miniatures.  Certain similar elements are present, true, but can readily see the profiles don't match.  Now, it is possible individual pieces might have been reused (though I can't be certain) but the overall "frames" are all distinctively different.
    Sincerely,
    Bill
