Can't open any files: "An error occurred while reading the file, see the log file for more details"
Just found DAZ last night and did a fresh install. Never used 3d software before but was messing around with it. Saved a file and quit out of the application. Came back around today to find that DAZ is unable to open my files. So i did a re-install: no luck.
Heres the log file:
2019-02-23 16:48:59.232 WARNING: cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
2019-02-23 16:55:26.612 WARNING: cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
2019-02-23 17:02:03.020 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
2019-02-23 17:08:51.422 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
2019-02-23 17:09:45.281 *** Scene Cleared ***
2019-02-23 17:09:45.594 Error reading file, see log for more details.
2019-02-23 17:11:00.245 *** Scene Cleared ***
2019-02-23 17:11:00.549 Error reading file, see log for more details.
I have no idea what any of that means. I'm completely new to this technology. If its relevant, DAZ (4.10) is installed under my C: drive under Program Files (x86). The save files seem to be coming from my Documents folder (Documents>DAZ 3D>Studio>My Library>scenes. I'm pretty frustrated that I can save files but never retrieve them :/.
  • Same problem. No Idea
  • With what or how did you install the content and to where? You don't want it stored in the cloud AFAIK.
  • LeanaLeana Posts: 13,504
    The default directory for Connect install is called "cloud" though it's a local directory
  • DrunkMonkeyProductionsDrunkMonkeyProductions Posts: 1,311
    edited February 2020
    Couple possibilities for the "error reading file" message.
    Either the scene file is corrupt or something in that file is causing the error.
    Try creating a primative, square, plane, whatever and saving that as a scene.
    If it errors on a reload, i'd say you might have a drive problem or DS is corrupted.
    Try reinstalling DS and try the primative scene again.
    If it's still erroring out, it might be a bad install or something else may be causing the issue.
    Post edited by DrunkMonkeyProductions on
  • Did you save (File>Save) or did you pick one of the options from File>Save As? If the latter, some of those are presets that require a target item to be loaded and selected, and that is the error that you get if you try loading them without a target selected.
