Genesis 8 male shape problems
gremlin-2297907
Whenever I load a genesis 8 male it loads already filled with morphs. No matter what character I load. Here is an example of the base male loaded... what to do?
Image deleted for nudity
Check the Currently Used group in the parameters pane - it's likely that one or morphs are loading with a default non-zero value, probably from a character set you had installed just before the issue started though use of File>Save As>Support Assets>Save Modified Assets can also do it.
