Courageous for V4 Seam Guides?
Does anyone have those? Googled all over, but can't seem to find them.
  • MelanieLMelanieL Posts: 7,889
    edited February 2019
    If Snow Sultan has a set for this outfit then they are the best, or for the original DAZ templates try the Wayback Machine: https://web.archive.org/web/20130613104736/http://www.daz3d.com:80/courageous-for-v4
    "Resource Files" tab - then the .exe file if you are PC or the .zip file if you're Mac (this is NOT in the same format as the .zip files you get for templates nowadays from your Product List, so can't be used on a PC)
    ETA: If this takes you to another panel which says " Hrm. The Wayback Machine has not archived that URL. This page is available on the web!" then click on the "save this url in the Wayback Machine" and you'll get the file downloaded.
    The .exe file is an installer - you need to specify where to put the templates, this can be anywhere you like where you can find them again (they don't need to be in your DAZ content library unless you want to put them there)..
    Post edited by MelanieL on
  • SnowSultanSnowSultan Posts: 3,847
    I don't think I ever made seam guides for that set, very sorry.
  • Thank you so much MelanieL. That worked. smiley  yes You are a life saver!!!
    @SnowSultan, that is fine ;) The ones you have made are always appreciated. Thank you for all your work
