More Iray questions from a latent N00B
StratDragon
After a long hiatus from 3D I've gone ahead and installed DS4.10 and decided to try Iray out. I don't have a Nvidia card, and I'm not installing one any time soon, but I don't mind CPU rendering and my computer has plenty CPU and RAM. So here are some questions:
Can I stop a render and continue it some other time, like after I've quit DS, restarted and opened it a week later?
Can I save a project and render it externally?
Can I adjust the lighting in a scene while the render is taking place?
Is there documentation on what the settings in Iray do in DS, but in layman terms?
Is there any information about DS becoming exceedingly unresponsive after some time that has nothing to do with interface settings or complexity of a scene? Meaning I work on a scene, the system becomes slower, I save the scene, I quit DS, open it back up, reload the same scene and it's humming right along.
also, is the bug reporting system still a thing?
[edit] more questions @ about 2:30 PM EST
whats the difference between dome and sun? In lux you create a light, name it sun and position it where you want the light to come from. How is this done in Iray?
what is the difference between metallic and glossy. It appears that any time I convert my shaders with the Iray uber they convert to metallic. Do I want this or do I need to change things like skin and hair to "glossy"?
Hope this helped!
Thanks Paradigm! I'm rushing ahead when I need to take this slowly. This is great info!
Yes - and no. Render to new window; to adjust the amount of light, cancel the render but do NOT close the window. There is a small tab on the left side; if you click on it you get a fly-out tab that lets you change to f-stop, the film iso, and the shutter speed. AFAIK, there is no way to change the direction or location of the light. Once you've changed the exposure settings you can click on the 'Resume' button on the render window.
I have found that, but thank you none-the-less. I didn't know if there was another way. The ability to move lights as you render was not something Lux could do either, although I've read Iray can ghost a light so it doesn't appear in the scene. I have no tried that yet because I have no idea how to do that.
You know you stop using software for a few years and everything up and changes on you!
oof, that's news to me lol. I've wasted dozens of hours cancelling renders to adjust their lights and start again.
actually I didn't know about the tab, I was going back to the render panel
FWIW, you don't even need to cancel the render first — just open the fly-out panel, make the tonemapping changes, and the scene lighting will change at the next render view redraw; I've never had it take more than about 10-20 seconds, usually a lot less.
great!
Does anyone know where I can find the answer to these two questions though?
Dome uses an HDRI image, if one issn't asigned it functions like Sun & Sky with the addition of the ability to use local lights. You can assign a Sun Node, which allows you to use a camera or light to show where the sun is shining from.
Metallic is for dielectric surfaces, glossy for others - I would think metallic was not right for hair, but whatever works for you is the one you should use (metallic lighting model was often used for 3Delight hair and fur).
Thanks Richard.
1) If I create a sun node do I turn off dome off/on/other?
2) when the Iray ubershaders sets a human skin to "metallic" it's not a a given and tweeking is manditory?
Meaning if you were trying to replicate skin as close to "human" skin it doesn't matter if you use Metallic or Specular? Other than Metallic being easier for most people does it have any other advantage to "organic" materials? I don't even know what weighted is yet, I haven't gotten there.
It does not matter. Its to taste. For me, Metallic/Roughness is the better choice because I find the gloss settings easier to grok. I'm not sure I will ever get a good handle on Spec/Glossi.
