Wanting to post new freebie in freebie section but need guidance first..
Ghosty12Ghosty12 Posts: 2,093
edited October 2013 in The Commons
Heya I have created a new teeth morph for Genesis 2 Female and well before I post it here I want to know how to really know that the DSF file that I have created has no other morphs in it that should not be there, ie for copyright reasons.. The file is about 2Kb in size tried tie read the file to check that there was not anything there that should not be but could not due to it being unreadable..
Is there a way to know what is included in the file or am I out of luck, I did do the reverse thingy during the importing from Hexagon to Daz Studio but not sure if it got rid of the unwanted morph settings..
Any help please would be greatly appreciated thank you.. I would like to post them here but also don't want to get in trouble for posting a file that might have other morph settings that should not be in there..
Post edited by Ghosty12 on
  • Richard HaseltineRichard Haseltine Posts: 111,315
    The morph file won't tell you - if there are changes from the DAZ morphs embedded in the morph they will just change the deltas, they won't be listed by name. If there are morphs listed then they will be links to other morphs, not the morphs themselves, and that's fine. If you aren't sure that you removed the DAZ morphs then I don't think there's really anything you can do - though if you applied Reverse Deformations with the figure in the same state as when you sent it to hexagon you should be clean.
    You can in fact read the file by uncompressing it - with the Batch Convert pane in DS or by using something like 7Zip.
  • Ghosty12Ghosty12 Posts: 2,093
    Thank you for the info will look into it as do want to post this morph. :)
