Quick dForce question
I love dForce but I have a perticular problem. I want to drop a dForce clothing item to the floor. Most will do this fine, but I have a top that hangs from the shoulders and won't fall. I think the old term used with cloth dynamics is "constrained poligons". How do I remove the this from a dForce clothing item? Thank you.
  • Check the surfaces for the item - it may be that there is a separate one for the pinned area and it has its Dynamic Strength property set to 0. If that isn't it there's probably a weight map, you can modify or remove that by selecting the dForce item and going to Create>New dForce Weight map access node - with the Nodw Weight Map Bruish tool active you will then be able to disable the map in the Tool Settings pane.
    Thank you Richard
