Linda Hair and GPU failed - iRay GTX 1080
Hi All,
This is a simple one - loaded Linda Hair for G3F from OOT in the scene and iRAY falls back to CPU:
2019-02-17 16:34:49.503 Iray INFO - module:category(IRAY:RENDER):   1.4   IRAY   rend info : CUDA device 0 (GeForce GTX 1080): Scene processed in 16.574s2019-02-17 16:34:49.506 Iray INFO - module:category(IRAY:RENDER):   1.4   IRAY   rend info : CUDA device 0 (GeForce GTX 1080): Allocated 28.8064 MiB for frame buffer2019-02-17 16:34:49.506 Iray INFO - module:category(IRAY:RENDER):   1.4   IRAY   rend info : CUDA device 0 (GeForce GTX 1080): Allocated 1.65625 GiB of work space (2048k active samples in 0.000s)2019-02-17 16:34:49.507 Iray INFO - module:category(IRAY:RENDER):   1.4   IRAY   rend info : CUDA device 0 (GeForce GTX 1080): Used for display, optimizing for interactive usage (performance could be sacrificed)2019-02-17 16:34:49.513 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.7   IRAY   rend error: CUDA device 0 (GeForce GTX 1080): Kernel [0] failed after 0.006s2019-02-17 16:34:49.513 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.7   IRAY   rend error: CUDA device 0 (GeForce GTX 1080): an illegal instruction was encountered (while launching CUDA renderer in core_renderer_wf.cpp:807)2019-02-17 16:34:49.514 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.7   IRAY   rend error: CUDA device 0 (GeForce GTX 1080): Failed to launch renderer2019-02-17 16:34:49.514 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.4   IRAY   rend error: CUDA device 0 (GeForce GTX 1080): Device failed while rendering2019-02-17 16:34:49.514 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(IRAY:RENDER):   1.4   IRAY   rend warn : All available GPUs failed.
Using latest drivers from nvidia, previous ones had the same issue.
The annoying bit is that any other file loaded will also use the CPU. and only restarting Daz will fix the problem of iRay ignoring my GTX 1080
Ive made sure that CPU is unchecked, and optix on and off. Still getting this issue.
Any tips? I really like the hair from OOT and dont want to get other hair and suffer the same fate.
  • barbultbarbult Posts: 27,474
    What version of graphics card driver are you using. It is a known issue that anything over 417.71 falls back to CPU. There are a bunch of threads in the forum about that problem. Nvidia is aware and working to fix it.
  • 418.91
    But this happens only with OOT's Linda hair though, everything else is fine
    edited February 2019
    Well, I can't explain that! Edit: unless you have a driver so new it has a fix, and Linda hair is so memory intensive it won't fit in your 1080.
    Post edited by barbult on
    @artphobe
    You should at least roll your Nvidia driver back. I NEVER use the latest Nvidia driver anymore (5+ years). Except for generational changes, driver updates are for game specific reasons and won't impact rendering.
    Still, if it's not the driver, you hace something else going on. I've attached an 80% render of Linday Ponytail on G8F. Used 3356MB on my GTX980TI. It's not the hair.
    1001 x 667 - 800K
    Post edited by Chohole on
  • artphobeartphobe Posts: 97
    fastbike1 said:
    @artphobe
    Thanks, which driver version are you using? 417.71?
  • Philippi_ChildPhilippi_Child Posts: 680
    fastbike1 said:
    @artphobe
    Fastbike1 I'm with ya I'm still using driver 397.93 from May 2018 that was the last time I updated a driver.
    Post edited by Philippi_Child on
  • scorpioscorpio Posts: 8,533
    fastbike1 said:
    @artphobe
    I just checked and I'm a bit more up to date; I'm still using 398.36 from June, this is the one my computer came with loaded when I bought it last September.
    Away from main pc but think I’m using either 397.93 or 398.36. I have to have a compelling reason and all the games run well enough with these.
  • takezo_3001takezo_3001 Posts: 2,041
    419.17 is out and it seems to correct the GPU dropping to CPU, at least with my system; I'm using a GTX 1080... hope this helps!
