Dream home walls transparent? (SOLVED)
My real question is more general; can you make walls transparent?
I am asking cause I bought most of the parts of the great Dream Home-set. Some of the rooms are quite small and hard to make a scene in because a lot of times I want to view the scene from some distance, but the walls block the view.
I would like to the make the wall I am looking through transparent. Is it possible? If so; how?
Post edited by reserv888 on
Select the wall, then click on the little 'eye' icon in the Scene pane to make the wall invisible.
You could also make the surface material completely transparent in the Surfaces pane, but switching off the visibility is much easier.
Thx Jimmy. It was that easy. Didn't even try that. Thought the whole rome was an entity. Thx again.
