GPU failed to render OOT Hair
I'm still very new to daz (currently using 4.10 Pro) so I'm sorry if this question is asked before. So, I've been trying to setup a scene using outoftouch's charlene hair, but my GPU (GTX 1060 6GB) always failed to render it and end up using CPU which take time forever! At first, I thought because my scene was too complex and my GPU ran out of memory, so I tried a very simple scene with just Victoria 7 figure and the OOT hair with lighting come from default dome, but the render still end up with CPU. I already made sure that only my GPU was checked on render settings. I have another OOT Hair from outoftouch, Claudia Hair and the result is still the same, my GPU failed to render it. This problem only happened with oot hair, I've tried several other non OOT Hair and my GPU rendered it all just fine. My GPU using the latest nvidia driver I downloaded from nvidia official site. Here is the log file. I really have no idea what happened so any thought is welcomed!
2019-02-15 00:58:19.810 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating geometry.
2019-02-15 00:58:19.878 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Using built-in ray tracing (1.0.0).
2019-02-15 00:58:19.891 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Importing scene graph.
2019-02-15 00:58:19.891 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Importing geometry.
2019-02-15 00:58:21.154 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Geometry import (1 object with 3352k triangles, 1 instance yielding 3352k triangles) took 1.262143
2019-02-15 00:58:21.154 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating materials.
2019-02-15 00:58:21.228 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(MATCNV:RENDER):   1.0   MATCNV rend warn : At 'DS_Charlene Hair Genesis 3 Female__Side2_49a_162.volume.absorption_coefficient': unsupported function call: 'operator/(color,float)'
2019-02-15 00:58:21.228 Iray INFO - module:category(MATCNV:RENDER):   1.0   MATCNV rend info : Material instance 'DS_Charlene Hair Genesis 3 Female__Side2_49a_162' uses MDL JIT compilation.
2019-02-15 00:58:21.228 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(MATCNV:RENDER):   1.0   MATCNV rend warn : At 'DS_Charlene Hair Genesis 3 Female__Side1_4cc_230.volume.absorption_coefficient': unsupported function call: 'operator/(color,float)'
2019-02-15 00:58:21.235 Iray INFO - module:category(MATCNV:RENDER):   1.0   MATCNV rend info : Material instance 'DS_Charlene Hair Genesis 3 Female__Side1_4cc_230' uses MDL JIT compilation.
2019-02-15 00:58:21.236 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(MATCNV:RENDER):   1.0   MATCNV rend warn : At 'DS_Charlene Hair Genesis 3 Female__Front2_4fe_299.volume.absorption_coefficient': unsupported function call: 'operator/(color,float)'
2019-02-15 00:58:21.236 Iray INFO - module:category(MATCNV:RENDER):   1.0   MATCNV rend info : Material instance 'DS_Charlene Hair Genesis 3 Female__Front2_4fe_299' uses MDL JIT compilation.
2019-02-15 00:58:21.242 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(MATCNV:RENDER):   1.0   MATCNV rend warn : At 'DS_Charlene Hair Genesis 3 Female__BackUnder_530_367.volume.absorption_coefficient': unsupported function call: 'operator/(color,float)'
2019-02-15 00:58:21.242 Iray INFO - module:category(MATCNV:RENDER):   1.0   MATCNV rend info : Material instance 'DS_Charlene Hair Genesis 3 Female__BackUnder_530_367' uses MDL JIT compilation.
2019-02-15 00:58:21.243 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(MATCNV:RENDER):   1.0   MATCNV rend warn : At 'DS_Charlene Hair Genesis 3 Female__Front1_562_436.volume.absorption_coefficient': unsupported function call: 'operator/(color,float)'
2019-02-15 00:58:21.250 Iray INFO - module:category(MATCNV:RENDER):   1.0   MATCNV rend info : Material instance 'DS_Charlene Hair Genesis 3 Female__Front1_562_436' uses MDL JIT compilation.
2019-02-15 00:58:21.250 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(MATCNV:RENDER):   1.0   MATCNV rend warn : At 'DS_Charlene Hair Genesis 3 Female__Bangs2_594_505.volume.absorption_coefficient': unsupported function call: 'operator/(color,float)'
2019-02-15 00:58:21.250 Iray INFO - module:category(MATCNV:RENDER):   1.0   MATCNV rend info : Material instance 'DS_Charlene Hair Genesis 3 Female__Bangs2_594_505' uses MDL JIT compilation.
2019-02-15 00:58:21.259 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(MATCNV:RENDER):   1.0   MATCNV rend warn : At 'DS_Charlene Hair Genesis 3 Female__Bangs1_5f0_643.volume.absorption_coefficient': unsupported function call: 'operator/(color,float)'
2019-02-15 00:58:21.259 Iray INFO - module:category(MATCNV:RENDER):   1.0   MATCNV rend info : Material instance 'DS_Charlene Hair Genesis 3 Female__Bangs1_5f0_643' uses MDL JIT compilation.
2019-02-15 00:58:21.260 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(MATCNV:RENDER):   1.0   MATCNV rend warn : At 'DS_Charlene Hair Genesis 3 Female__Back_622_711.volume.absorption_coefficient': unsupported function call: 'operator/(color,float)'
2019-02-15 00:58:21.271 Iray INFO - module:category(MATCNV:RENDER):   1.0   MATCNV rend info : Material instance 'DS_Charlene Hair Genesis 3 Female__Back_622_711' uses MDL JIT compilation.
2019-02-15 00:58:21.271 Iray INFO - module:category(MATCNV:RENDER):   1.0   MATCNV rend info : found 261 textures, 8 lambdas (1 unique)
2019-02-15 00:58:21.279 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating environment.
2019-02-15 00:58:21.279 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating lens.
2019-02-15 00:58:21.288 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating lights.
2019-02-15 00:58:21.288 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating object flags.
2019-02-15 00:58:21.288 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating caustic portals.
2019-02-15 00:58:21.288 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating decals.
2019-02-15 00:58:21.290 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Allocating 1 layer frame buffer
2019-02-15 00:58:21.305 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Using batch scheduling, architectural sampler disabled, caustic sampler disabled
2019-02-15 00:58:21.305 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Initializing local rendering.
2019-02-15 00:58:21.350 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Rendering with 1 device(s):
2019-02-15 00:58:21.350 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info :     CUDA device 0 (GeForce GTX 1060 6GB)
2019-02-15 00:58:21.359 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Rendering...
2019-02-15 00:58:21.359 Iray VERBOSE - module:category(IRAY:RENDER):   1.2   IRAY   rend progr: CUDA device 0 (GeForce GTX 1060 6GB): Processing scene...
2019-02-15 00:58:23.749 Iray VERBOSE - module:category(IRAY:RENDER):   1.5   IRAY   rend stat : Geometry memory consumption: 98.8422 MiB (device 0), 0 B (host)
2019-02-15 00:58:55.963 Iray INFO - module:category(IRAY:RENDER):   1.5   IRAY   rend info : Initializing light hierarchy.
2019-02-15 00:58:55.970 Iray VERBOSE - module:category(IRAY:RENDER):   1.5   IRAY   rend stat : Texture memory consumption: 1.97154 GiB (device 0)
2019-02-15 00:58:55.970 Iray INFO - module:category(IRAY:RENDER):   1.5   IRAY   rend info : Light hierarchy initialization took 0.00s
2019-02-15 00:58:55.971 Iray VERBOSE - module:category(IRAY:RENDER):   1.5   IRAY   rend stat : Lights memory consumption: 196 B (device 0)
2019-02-15 00:58:56.117 Iray VERBOSE - module:category(IRAY:RENDER):   1.5   IRAY   rend stat : Material measurement memory consumption: 0 B (GPU)
2019-02-15 00:58:56.167 Iray VERBOSE - module:category(IRAY:RENDER):   1.5   IRAY   rend stat : Materials memory consumption: 105.758 KiB (GPU)
2019-02-15 00:58:56.167 Iray VERBOSE - module:category(IRAY:RENDER):   1.5   IRAY   rend stat : PTX code (8.16 KiB) for sm61 generated in 0.0491s
2019-02-15 00:58:56.409 Iray INFO - module:category(IRAY:RENDER):   1.5   IRAY   rend info : JIT-linking wavefront kernel in 0.153s
2019-02-15 00:58:56.449 Iray INFO - module:category(IRAY:RENDER):   1.5   IRAY   rend info : JIT-linking mega kernel in 0.039s
2019-02-15 00:58:56.455 Iray INFO - module:category(IRAY:RENDER):   1.2   IRAY   rend info : CUDA device 0 (GeForce GTX 1060 6GB): Scene processed in 35.095s
2019-02-15 00:58:56.458 Iray INFO - module:category(IRAY:RENDER):   1.2   IRAY   rend info : CUDA device 0 (GeForce GTX 1060 6GB): Allocated 21.094 MiB for frame buffer
2019-02-15 00:58:56.512 Iray INFO - module:category(IRAY:RENDER):   1.2   IRAY   rend info : CUDA device 0 (GeForce GTX 1060 6GB): Allocated 1.65625 GiB of work space (2048k active samples in 0.054s)
2019-02-15 00:58:56.526 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.5   IRAY   rend error: CUDA device 0 (GeForce GTX 1060 6GB): Kernel [0] failed after 0.003s
2019-02-15 00:58:56.526 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.5   IRAY   rend error: CUDA device 0 (GeForce GTX 1060 6GB): an illegal instruction was encountered (while launching CUDA renderer in core_renderer_wf.cpp:807)
2019-02-15 00:58:56.526 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.5   IRAY   rend error: CUDA device 0 (GeForce GTX 1060 6GB): Failed to launch renderer
2019-02-15 00:58:56.532 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.2   IRAY   rend error: CUDA device 0 (GeForce GTX 1060 6GB): Device failed while rendering
2019-02-15 00:58:56.532 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(IRAY:RENDER):   1.2   IRAY   rend warn : All available GPUs failed.
2019-02-15 00:58:56.532 Iray INFO - module:category(IRAY:RENDER):   1.2   IRAY   rend info : Falling back to CPU rendering.
2019-02-15 00:58:56.532 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.2   IRAY   rend error: CUDA device 0 (GeForce GTX 1060 6GB): an illegal instruction was encountered (while initializing memory buffer)
2019-02-15 00:58:56.538 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.2   IRAY   rend error: All workers failed: aborting render
2019-02-15 00:58:56.538 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.2   IRAY   rend error: CUDA device 0 (GeForce GTX 1060 6GB): an illegal instruction was encountered (while de-allocating memory)
2019-02-15 00:58:56.545 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.2   IRAY   rend error: CUDA device 0 (GeForce GTX 1060 6GB): an illegal instruction was encountered (while de-allocating memory)
2019-02-15 00:58:56.559 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.2   IRAY   rend error: CUDA device 0 (GeForce GTX 1060 6GB): an illegal instruction was encountered (while de-allocating memory)
2019-02-15 00:58:56.565 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.2   IRAY   rend error: CUDA device 0 (GeForce GTX 1060 6GB): an illegal instruction was encountered (while de-allocating memory)
2019-02-15 00:58:56.565 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.0   IRAY   rend error: CUDA device 0 (GeForce GTX 1060 6GB): an illegal instruction was encountered (while de-allocating memory)
2019-02-15 00:58:56.571 WARNING: dzneuraymgr.cpp(307): Iray ERROR - module:category(IRAY:RENDER):   1.0   IRAY   rend error: CUDA device 0 (GeForce GTX 1060 6GB): an illegal instruction was encountered (while de-allocating memory)
2019-02-15 00:58:56.571 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : CPU: using 4 cores for rendering
2019-02-15 00:58:56.578 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Rendering with 1 device(s):
2019-02-15 00:58:56.578 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info :     CPU
2019-02-15 00:58:56.579 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Rendering...
2019-02-15 00:58:56.579 Iray VERBOSE - module:category(IRAY:RENDER):   1.2   IRAY   rend progr: CPU: Processing scene...
2019-02-15 00:58:56.588 Iray INFO - module:category(IRAY:RENDER):   1.2   IRAY   rend info : CPU: Scene processed in 0.009s
2019-02-15 00:58:56.595 Iray VERBOSE - module:category(IRAY:RENDER):   1.5   IRAY   rend stat : Native CPU code generated in 0.0086s
2019-02-15 00:58:56.603 Iray INFO - module:category(IRAY:RENDER):   1.2   IRAY   rend info : CPU: Allocated 21.094 MiB for frame buffer
2019-02-15 00:58:58.914 Iray INFO - module:category(IRAY:RENDER):   1.2   IRAY   rend info : Allocating 1 layer frame buffer
2019-02-15 00:58:59.005 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00001 iterations after 37.605s.
2019-02-15 00:59:01.261 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Received update to 00002 iterations after 39.861s.
  • nicsttnicstt Posts: 11,715
    edited February 2019
    OOT's hair can be tough on resources; try rendering with just the hair in the scene, literally nothing else. If it works then it isn't the hair per se.
    You could also try reducing the texture sizes of the hair.
    Whilst I have a number of OOT's hair, I don't have that one; maybe someone else who owns it will pop by.
    Post edited by nicstt on
  • nDelphinDelphi Posts: 1,987
    Seems like your scene didn't fit in your video cards memory.
  • Twilight76Twilight76 Posts: 318
    You need the old nvidia driver (417.71) the new 418.x has problems with iray at the moment.
    From driver 418.91 release notes, known issues section, page 15:
     - [Iray][OptiX]: Iray GPU acceleration crashes and falls back to CPU acceleration. [2503738]
    Post edited by Twilight76 on
  • OOT Tends to use 8K textures on every single hair surface, so you either need to invest in Scene Optimizer or the freebie texture reducer here or here, in order to make the hair fit on your graphics card. I have a 6gb card as well and have problems even with their male hairs not fitting.
  • Unless I'm misreading the log, isn't the texture consumption less than 2 gigs? So it shouldn't be that alone...
    I should have caught it, he did say he updated the NVIDIA driver, in that case it's also an issue, he needs to downgrade to 417.71 as the newset drivers have changed and DAZ Studio needs to catch up.
  • FSMCDesignsFSMCDesigns Posts: 12,858
    Good thing I have all those options as thst is just overkill IMO
    It has nothing to do with Daz. Nvidia has admitted the recent drivers break iray and optix. Its in the patch notes
    I tried to use some freebie texture reducer you mentioned but the problem still exist.
    I think this is most likely the cause. I think I'll just wait for now until nvidia release new update driver. I'm not sure using old version is good idea because I also use this gpu for extensive gaming and it's been working wonder so far.
  • pfunkyfizepfunkyfize Posts: 496
    All My OOT hairs were forcing my renders down to the CPU also. I just loaded the latest Nvidia driver for my 1080TI, 419.67, and I can confirm the problem with Linda hair and the rest of my G3F/G8F OOT hairs are running fine on the GPU now.
